Thread started 29 Aug 2008 (Friday) 17:59
Turning of the "flash flash it self"
DerekRob
Aug 29, 2008 17:59 |  #1
How do I turn off the flash "light" it self so it only emits the been?
By the way I have 430 ex speedlite now.
Curtis ­ N
Master Flasher
Aug 29, 2008 18:08 |  #2
I presume you're referring to the AF assist light.
No way that I know of with the camera bodies you have.
20D, 30D, 40D and some higher end cameras have a custom function to prevent the flash from firing.
DerekRob
Aug 29, 2008 18:18 |  #3
Curtis N wrote in post #6205868 (external link)
Sorry Curtis,
I own the 400D and the 450D, my mum is using my 400D and I'm using the 450.
I just purchased the flash 2 hours ago.
tim
Light Bringer
Aug 29, 2008 18:20 |  #4
I think Curtis read it backwards - easy to do as the OP isn't clear. To keep the AF beam but turn the flash off I use the menus of my 40D. For earlier cameras it was a custom function.
Lotto
Aug 29, 2008 19:05 |  #5
Flash to manual mode at 1/64, turn the flash head pointing backward.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
Curtis ­ N
Master Flasher
Aug 29, 2008 20:55 |  #6
For clarification -
There is custom function on the 40D and some other bodies, but not on the 400D or 450D, that prevents the flash from firing but allows the AF assist beam to operate normally.
If this is not what the OP is trying to do, then I invite him to further explain his question.
DerekRob
Aug 29, 2008 21:12 |  #7
Curtis N wrote in post #6206512 (external link)
For clarification -
I'm trying to set the 430 ex up so if I went to a blues club will not irritate the performers with a flash every 5 minutes or something to that effect.
tim
Light Bringer
Aug 29, 2008 21:29 |  #8
So you want the AF assist beam but no flash? Don't know on your cameras. Does your flash have custom functions that can turn it off?
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Aug 29, 2008 22:08 as a reply to  @ tim's post |  #9
The manuals for the 400D and 450D do not include this in the list of Custom Functions, so the answer is "No, the flash cannot be suppressed by those cameras' menus.".
So, if the 430EX flash is being left on the camera, use the power switch to turn it off, and focus manually.
Both cameras have a menu Custom Function for turning off the auto-assist beam and leaving the flash functioning!
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
Lotto
Aug 29, 2008 22:18 |  #10
With the XTs, the flash can't be turned off but leave the focus assist active. Just set the 430 to minimum and tape up the flash head.
tim
Light Bringer
Aug 29, 2008 22:32 |  #11
Could you perhaps tape the center of the contact on the flash to let everything except the "fire" command get through? This is just a guess, never tried it, hopefully it won't hurt anything.
PacAce
Joined Feb 2003
Aug 29, 2008 22:53 |  #12
The feature for turning off the flash on the 450D is not a custum function but a regular menu option, the 5th tab from the left. Select that tab, then select Flash control and then set Flash firing to Disable.
Unfortunately, there is no equivalent feature on the 400D, AFAIK.
...Leo
CliveyBoy
Joined Nov 2005
Aug 30, 2008 00:14 as a reply to  @ PacAce's post |  #13
Ah - didn't think of looking on the main menu!
The custom functions are a hangover from old binary switches, and the more that Canon moves them to standard menus, the better IMO.
DerekRob
Aug 30, 2008 08:34 |  #14
Thanks guys and gals you really helped me out.
1,017 views & 0 likes for this thread, 6 members have posted to it.
2797 guests, 138 members online
