Thread started 31 Aug 2008 (Sunday) 08:43
Issue with merging GeoTag data w/Photo
tmwhitm
Aug 31, 2008 08:43 |  #1
Was wondering if anyone has run into this issue. I am using a Garmin V GPS to capture my track. I transfer the track to MapSource and save the file in the .gpx format. I have used Microsoft Photo and GPSSync to attempt merging the location information into the photo only to find that the location is not correct. The date/time of the GPS and the Camera are matched to within one minute. What I have discovered is that the location information in MapSource is not the same information saved to the .gpx file. MapSource appears to have the data in degrees and minutes and the .gpx file has it as longitude and latitude. I have looked over a lot of settings but can't seem to come to a conclusion. Any idea's is greatly appreciated...
Thanks,
Tom
Canon 30D | Canon 7D | Canon R6 |Sony α6000 / ILCE-6000 | Sony E 3.5-5.6/PZ 16-50 OSS | Sigma DC 17-70mm | Canon EF 70-200mm f/2.8L USM | Canon EF 70-200mm f/2.8L IS II USM |Canon EF24-105mm f/4L IS USM | Canon RF 50mm f/1.8 STM
Sorarse
Aug 31, 2008 10:33 |  #2
Not sure what you mean when you say that Mapsource has data in degrees and minutes and .gpx file has it in lat and long, because degrees and minutes are one way of measuring lat and long.
Are you getting any error messages when trying to attach the gps data to your photos when using GPSync?
I found that whilst my GPS and camera were showing the same time, photos were being logged to the wrong location. I subsequently discovered I need to readjust the UTC time in GPSync during tagging to get the photos logged to the correct location.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
tmwhitm
Aug 31, 2008 12:22 as a reply to  @ Sorarse's post |  #3
Thank you for responding. Below is an example of the data. I may be explaining it incorrectly.
This is how Mapsource displays the location
"1 8/23/2008 3:09:54 PM 352 ft 4 ft 0:00:01 3 mph 286° true N41.39109 W73.19053"
This is what is displayed in the .gpx file,
<trkpt lat="41.391093" lon="-73.190532">
<ele>107.324341</ele>
<time>2008-08-23T19:09:54Z</time>
</trkpt>
If I take what is in the .gpx file, it maps to a different location.
tmwhitm
Aug 31, 2008 12:23 as a reply to  @ tmwhitm's post |  #4
I also noticed that I need to adjust the time after receiving multiple errors. But even with the time adjusted, it is still not correct.
Nanscombe
Aug 31, 2008 13:23 |  #5
tmwhitm wrote in post #6214148 (external link)
</trkpt>
Hi,
They should be the same.
N41.39109 is Latitude 41.39109 degrees North
W73.19053 is longitude -73.190532 East (or 73.190532 degrees West).
They are also decimal figures not Degrees, Minutes and Seconds.
Nigel
Citizensmith
Joined Dec 2004
Aug 31, 2008 13:36 |  #6
Yup, both have the same data, location in decimal degrees with more accuracy than a Garmin V is even capable of. 4 or 5 decimal places is more like it.
Latitude is how far north or south you are. Longitude is how far east or west you are. Negative in this case because you are west.
Rather than over analyzing how the systems describe their data, have you actually looked on a map to see if it is in the right place? That would really let you know if you have an issue.
My POTN Gallery, Complete gear list,
Tradition - Just because you've always done it that way doesn't mean it's not incredibly stupid.
Sorarse
Aug 31, 2008 15:28 |  #7
According to the information you have given, those co-ordinates show that the photograph was taken as shown on the attached image. If this isn't where the photo was taken from, I would suggest that there is still a discrepancy between the times on your camera and your GPS.
I find that with mine, even though the camera and GPS are synchronised, the software I use for Geotagging needs to have the time offset by 1 hour, because we are currently on BST - which is what the camera is set to. The GPS is on UTC but has automatic adjustment for BST.
Canon PowerShot G2
tmwhitm
Aug 31, 2008 16:56 |  #8
It is strange because that is not where the photo was taken. It was actually taken about 10 miles north east of this location. I did check these coordinates on google maps to confirm. Is the 'Z' next to the time in the .gpx file Zulu time? Would the offset have to be more than -5 for US Eastern?
Sorarse
Aug 31, 2008 18:02 |  #9
It would be a fair assumption that the Z stood for Zulu time i.e. GMT, and that you will need to allow for the offset if your camera is set to a different time zone.
If US Eastern is GMT -5, perhaps you can re-tag your photos with that offset dialled in to your Geotagging software, and see what co-ordinates are then attached to your photos.
Canon PowerShot G2
Citizensmith
Joined Dec 2004
Aug 31, 2008 20:12 |  #10
tmwhitm wrote in post #6215354 (external link)
But you must have been there at some point for your GPS to have that location. If you can look at all the locations and figure out what time the GPS thinks it was and what time your camera thinks you should be able to see what the time offset should be.
tmwhitm
Aug 31, 2008 21:20 |  #11
Thank you all. I believe I understand the problem. Eastern Standard Time is -5 hours from UTC but during Daylight savings it is only -4 hours. When I saved the track in the .gpx format, 3:09:54 PM, 15:09 military time, was saved as 19:09Z time. I was looking for 5 hours to be added to the local time, not 4. When I set the UTC offset in the GPSSync software to -4, the photos are geotag very accurately. All of our clocks are set to manage this difference so I didn't give it much thought. If you are curious, there is a table at the bottom of this link that shows the offsets.
http://www.dxing.com/u​tcgmt.htm (external link)
Thanks again for everyone's input. It's always little details that bite you...
Nanscombe
Sep 01, 2008 01:41 |  #12
Doh!
It was the time offset! I was so intent on the co-ordinates that I didn't think of the time.
That, I suppose, is where the UK is lucky just being in one time zone.
Glad it's sorted.
Nigel
Sorarse
Sep 02, 2008 09:59 |  #13
Nanscombe wrote in post #6217810 (external link)
Doh!
Glad it's sorted.
Actually we're not - we have daylight saving too, which means that in summer months if I want to Geotag my photos I have to set the time offset in my tagging software to 1 hour.
Canon PowerShot G2
Nanscombe
Sep 02, 2008 10:42 |  #14
Sorarse wrote in post #6225491 (external link)
The whole of the UK is shares the same time which changes between BST (British Summer Time) and GMT (Greenwich Mean Time) twice a year.
I just adjust my camera clock(s) along with all of the rest of my clocks.
My GPS and computer adjust themselves automatically.
Nigel
1,945 views & 0 likes for this thread, 4 members have posted to it.
1458 guests, 128 members online
