Well, I think I made a decision.
The Slik 340DX just sounds too nice to pass up with its low weight and folded length. The times I will be using it and the size/weight factor is NOT an issue will not be as frequent as when they WILL be a factor, if that makes any sense...
IE: I will use this more during international travel, hiking/outdoorsy stuff vs. indoor weddings and portraits.
The B/M 488RC2 sounds awesome, havent heard a bad thing about it, hopefully it will be money well spent.
Lastly, is there anything I need to buy in addition to these to make them work together? Adapters, special plates, brackets, etc? Will the two essentially be a "plug and play"?
The head nor the tripod comes with a level, so I was going to buy a hot shoe mounted one to ensure the proper angle. I saw B&H has several listed, is there any particular one to stay away from or to get?
I cant thank everyone from this site enough for their time and patience, this hobby is a little expensive to get started, but hopefully will be well worth it!
