I am confused about ho to set the 580 EX II so that it exposes correctly while triggered remotely using pocketwizards. Do I leave it at ETTL, manual or set it as Master or something else?
jerrybsmith Senior Member 299 posts Joined Jan 2006 Location: Houston, TX More info | Sep 01, 2008 07:50 | #1 I am confused about ho to set the 580 EX II so that it exposes correctly while triggered remotely using pocketwizards. Do I leave it at ETTL, manual or set it as Master or something else?
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Sep 01, 2008 07:52 | #2 Radio slave systems require the flash to be in manual. The only exception is radiopoppers, which have magic inside them which extends ETTL over a radio channel. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Andrushka "all warm and fuzzy" 3,735 posts Likes: 12 Joined Oct 2007 Location: OC, CA More info | Sep 01, 2008 07:52 | #3 |
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 01, 2008 07:53 | #4 When used with a radio slave system such as the PocketWizard family (or most other radio slave systems), there is no way for a camera and flash unit to communicate information other than the camera sending a "go" signal to the flash via the radio link. Thus, the flash unit's output will have to be controlled manually. Skip Douglas
Titus213 Cream of the Crop More info | Sep 01, 2008 20:29 | #5 Does the 580EX II need to be attached to the camera to use its 'auto' mode - as in auto-thyristor? Dave
msowsun "approx 8mm" More info | Sep 01, 2008 21:12 | #6 The 580EX II can also be used off camera in 'auto' mode - as in auto-thyristor. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Titus213 Cream of the Crop More info | Sep 01, 2008 21:38 | #7 So it could be put in auto mode and attached to a Pocket Wizard? Dave
msowsun "approx 8mm" More info | Sep 01, 2008 22:41 | #8 Yes, I believe so. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
JKacey Goldmember 1,142 posts Likes: 3 Joined Jan 2007 More info | Sep 01, 2008 23:14 | #9 It's my understanding the 580 EX II sync port is disabled off camera in Manual mode. You need to get a hot shoe adapter....... Or my suggestion would be to send it into http://www.michaelbass.blogspot.com/
msowsun "approx 8mm" More info | Sep 01, 2008 23:34 | #10 No, the PC sync port is only disabled in the Master-Slave setup. It should work fine in manual or external metering. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Titus213 Cream of the Crop More info | Sep 01, 2008 23:44 | #11 What I was getting at is that the OP could hook the 580EX II up to a radio receiver in 'Auto' mode and get some reasonably exposed shots without too much difficulty. Dave
msowsun "approx 8mm" More info | Sep 02, 2008 00:01 | #12 Yes, I agree. The Pocket Wizard would work well with a 580EX II and still give you auto flash exposure if you set the Custom Function to CF 5-3 (External metering: Manual). Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
CliveyBoy R.I.P. He will be missed 3,272 posts Likes: 42 Joined Nov 2005 Location: Tauranga, NZ More info | Sep 02, 2008 00:30 | #13 msowsun wrote in post #6223456 But you have to remember that the auto flash exposure is being read by the font of the flash. If you have the located away from the camera, and are lighting the side of the subject, the flash will see a different exposure than the camera does. For best results in External metering mode, the flash should be in a position that is similar to the camera position. I think that it is different than that. When you invoke the "External Automatic Flash Exposure Sensor" you need to set the ISO, Aperture and Shutter Speed settings you want (say from a light meter) and the sensor will enable that amount od light to be emitted. Clive, and Great G/D Abbie
msowsun "approx 8mm" More info | Sep 02, 2008 00:39 | #14 CliveyBoy wrote in post #6223555 To see the deep workings of this new facility, look at: http://www.usa.canon.com …tArticleAct&articleID=946 Definitely a good read if you are at all considering using the 580EX II "External Automatic Flash Exposure". Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Titus213 Cream of the Crop More info | Sep 02, 2008 00:51 | #15 CliveyBoy wrote in post #6223555 I think that it is different than that. When you invoke the "External Automatic Flash Exposure Sensor" you need to set the ISO, Aperture and Shutter Speed settings you want (say from a light meter) and the sensor will enable that amount od light to be emitted. To see the deep workings of this new facility, look at: http://www.usa.canon.com …tArticleAct&articleID=946 I'm reading that as setting the ISO and Aperture you want and then matching the camera settings to it. Which is pretty much traditional auto-thyristor mode. You set your desired lighting on the flash and then match the camera to that. Dave
| Latest registered member is Marcsaa 971 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
