A 50mm lens on a 1.6x body ends up being 80mm. But, is there a prime lens for the 1.6x bodies that ends up being 50mm once the crop factor is taken into account?
Thanks in advance
FlipsidE Goldmember 1,701 posts Joined Oct 2004 Location: South Carolina USA More info | Sep 01, 2008 12:57 | #1 A 50mm lens on a 1.6x body ends up being 80mm. But, is there a prime lens for the 1.6x bodies that ends up being 50mm once the crop factor is taken into account? FlipsidE
othomas Senior Member 531 posts Joined Oct 2005 Location: Midlothian, Scotland More info | Sep 01, 2008 13:00 | #2 Try focal length divided by the crop factor - ie 50/1.6 = 31.25. So 30mm should see the same, if not similar results.
edrader "I am not the final word" More info | Sep 01, 2008 13:03 | #3 FlipsidE wrote in post #6220044 A 50mm lens on a 1.6x body ends up being 80mm. But, is there a prime lens for the 1.6x bodies that ends up being 50mm once the crop factor is taken into account? Thanks in advance the closest are sigma 30 1.4 or canon 28mm. http://instagram.com/edraderphotography/
Sep 01, 2008 13:06 | #4 Exactly what I needed to know. Thanks for the info! FlipsidE
twoshadows Liquid Nitrogen 7,342 posts Gallery: 52 photos Best ofs: 19 Likes: 4905 Joined Jul 2007 Location: Between the palms and the pines. More info | Sep 01, 2008 13:06 | #5 Generally, people use the 28mm f/1.8 or 35mm f/2 for a roughly 50mm equivalent on a 1.6x cropper. If you're willing to go outside of Canon, the sigma 30mm seems to be a fine lens WHEN it is working properly (meaning: it may have to be returned for another or sent back to Sigma for calibration.) Of course there's the 35L as well xgender.net
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 01, 2008 13:13 | #6 FlipsidE wrote in post #6220044 A 50mm lens on a 1.6x body ends up being 80mm. But, is there a prime lens for the 1.6x bodies that ends up being 50mm once the crop factor is taken into account? Though most of us who have been around on the forum for a while fully understand the quote above, the newbies who read this may not be so insightful. Skip Douglas
shutterfiend Goldmember 2,058 posts Joined Feb 2007 Location: NJ More info | Sep 01, 2008 14:21 | #7 Canon 28/1.8 https://photography-on-the.net …p=7812587&postcount=91776
TommySharp Member 61 posts Joined May 2005 Location: Ellerslie, Auckland, NZ More info | Sep 10, 2008 23:56 | #8 So am I getting this right???? Tommy
pixel_junkie Goldmember 2,013 posts Likes: 143 Joined May 2007 Location: Southern California More info | Sep 11, 2008 00:00 | #9 TommySharp wrote in post #6284412 So am I getting this right???? A 30mm lens on a 1.6x crop D-SLR will give me (roughly) the same photo as a 50mm lens on a full fram D-SLR...... I'm guessing I can expect to see the same angle of view, so what fits in the photo on one setup should be pretty close to what fits in the photo from the second setup.... Could anything else be different, bear in mind I have no idea what I'm talkign about. ![]() Yah, you got it - 48mm tho ...
drewski Member 53 posts Joined Aug 2008 Location: SF Bay Area, CA More info | Sep 11, 2008 02:03 | #10 TommySharp wrote in post #6284412 Could anything else be different, bear in mind I have no idea what I'm talkign about. ![]() depth of field, perhaps . . . though i don't have much more idea than you 5DMkIII | 7DMkII | M6 | EF 16-35 f4L | EF 24-105 f4L II | EF 70-300 f4-5.6
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 11, 2008 05:41 | #11 TommySharp wrote in post #6284412 So am I getting this right???? A 30mm lens on a 1.6x crop D-SLR will give me (roughly) the same photo as a 50mm lens on a full fram D-SLR...... I'm guessing I can expect to see the same angle of view, so what fits in the photo on one setup should be pretty close to what fits in the photo from the second setup.... Could anything else be different, bear in mind I have no idea what I'm talkign about. ![]() You got it right. Skip Douglas
cherrymoon Senior Member 533 posts Joined Mar 2008 More info | Sep 11, 2008 07:20 | #12 Sigma 30mm f/1.4 is the best alternative : fast "usm", f/1.4, same focal (50mm/1.6 = 31.25mm)... This lens had very good reviews. But it's only available for APS-C sensor. 5D² 40 pancake | 50/1.4 | 85L II | 135L | 16-35L IS | 24-105L | 70-200 f2.8 L IS II and a TT bike
jemann Member 166 posts Joined Aug 2007 Location: Reading, United Kingdom More info | Recently bought a Canon EF 28 f/1.8 for this very reason. It's equivalent to 44.8mm on a full frame sensor. 7D, 100-400L, 5D2, 17-40L, 24-105L
TeeJay Goldmember 3,834 posts Likes: 4 Joined Jun 2005 Location: Warwickshire - UK More info | Sep 12, 2008 05:47 | #14 Also, although 30mm isn't especially "wide" - you could potentially see some additional distortion if you get too close to your subject - that you may not see with an actual 50mm 1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea
Bobster Cream of the Crop More info | Sep 12, 2008 05:51 | #15 i got a 2nd hand hardly used Sigma 28 1.8 and love it Robert Whetton
| Latest registered member is semonsters 1676 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
