Thread started 01 Sep 2008 (Monday) 15:01
Bridal session...C&C Wanted
MELIBRYM
Sep 01, 2008 15:01 |  #1
I am still learning, all C&C appreciated and thanks in advance...
Melissa ;)
MELIBRYM
Sep 01, 2008 15:02 |  #2
and a couple more...
Melissa ;)
Kiddo
Sep 01, 2008 15:14 |  #3
I really like the third and 4th ones that you posted... thanks for sharing.. The second one, maybe a different angle or something?? And the first one... as I was told by a well know photographer... Try not to put anything on the train... It kind of "ties" the bride down... But all in all, I think that you did a good job..
http://www.tanyaeveret​tphotography.com/ (external link)
http://tanyaeverettpho​tography.blogspot.com/ (external link)
Canon 30D, Canon 10D, Canon SXi, Canon EFS 18-55mm Lens, Canon EF 28-80mm Lens, Canon 75-300mm EF Lens, Canon EF 70-200mm f/2.8LUSM Lens, Speedlite 540EZ
paul33
Joined Aug 2002
Sep 01, 2008 16:37 |  #4
Decent effort but you've given yourself a tough lighting challenge there with subject in shade and a bright sunny backdrop. I would have looked for a more neutral background in order to bring out better colour in the subject.
Nene Digital Wedding Photography (external link)
Keithaba
Sep 01, 2008 17:16 |  #5
paul33 wrote in post #6221057 (external link)
That's right along the lines of what I was thinking. If you shot these exact same shots about 3-4 hours later, you would have had dramatically different outcome in terms of color and contrast. The shots are good, but the conditions under which you shot make it pretty tough to get a balanced photo without blown out highlights.
White is always tough to shoot, as it is easy to blow out the highlights. The sky is brutal in the shots you posted, and that makes for a tricky metering situation. You either get the bride in the correct exposure, or get the sky in the correct exposure. If the bride is correct, the sky is probably blown out. If the sky is correct, the bride is horribly under-exposed.
In your 4th pictures, you did the best thing you could, FIND SHADE!!!! If you crop out the sky, the exposure is petty good in #4. As Paul pointed out, you might want to avoid the sky at this time of day, and have her stand next to something like a big tree, or a tree line.
40D \ 350D \ 17-55 2.8 \ 70-300 IS \ 60mm 2.8 macro \ 28-135 IS \ Tamron 28-75 2.8 \ 580 EXII
MELIBRYM
Sep 01, 2008 17:44 |  #6
Thanks for the C&C....Yes the lighting was terrible. Unfortunately that is the time we were able to get together. She is a freind and is wearing a cheap dress I bought to practice photos with. I will definately try these again at a later time of day....THANKS
Melissa ;)
Skrim17
Sep 01, 2008 17:46 |  #7
you could increase the contrast a bit, did you do any processing of the images?
Crissa
JakPot
Sep 01, 2008 18:45 as a reply to  @ Skrim17's post |  #8
using fill flash here would have helped balance the background to the subject. The subject looks dull/flat... don't be afraid of using flash in these situations.
Philco
Joined Nov 2005
Sep 01, 2008 19:22 |  #9
I agree with what was said above...if you're in charge, pick a better time if you can. Reality is that you never get to pick the time of day for a wedding, so you do have to learn how to make the best use of the light where you are. In this case, that would probably mean exposing for the background and filling the foreground with flash, or split the difference and use a big reflector to bounce some light back onto the bride. Once the light is balanced, I think a wider aperture would go a long way toward separating the bride from the background. F2.8 or wider would make quite a difference, especially when it comes to creating an image that stands apart from a snapshot.
Canon 5D MKIII/Canon 5D MKII/ 70-200 F2.8 IS L / 24-70 F2.8L / 85 F1.2L II/ 35 f1.4L / 135 F2.0L / Canon 600 EX-RT X 2
[SIZE=1]r follow me on Facebook. (external link)
MELIBRYM
Sep 01, 2008 21:16 |  #10
I am still learning how to work with light and flash. I will have another go at it. Thanks for all the help. I did a little post processing, but I am still learning that too.
Melissa ;)
cjimenez
Sep 06, 2008 00:42 |  #11
Is she squinting, or is the sun really bright? Or is that her natural smile. I am not being mean I was just curious, I promise.
MOMIKE:)
Canon 40D / 580EXII / 28-135 / 50 1.8 / Sigma 24-70mm 2.8 and growing!
www.newschoolofphotogr​aphy.com (external link) COME JOIN
wroberts
Sep 06, 2008 09:10 as a reply to  @ cjimenez's post |  #12
This is my try at it, a quick 2 min. The 4th is a great pose; yes you did put yourself in horrible light situation, but you learn. Use your resources to your advantage (photoshop, actions if you have them). Keep up the good work.
Thanks,
wroberts
"What we do today will echo for all eternity"
MELIBRYM
Sep 06, 2008 22:05 as a reply to  @ wroberts's post |  #13
I like the edit....I have been working on it a bit and will try to repost my attempts. It is her natural smile and yes the sun was bright, so it may be a little of both. We are going to try a TTD session tomorrow. Thanks again for the comments and edits.
Melissa ;)
mauimau85
Sep 07, 2008 23:45 as a reply to  @ MELIBRYM's post |  #14
Another quick pp... maybe a bit overdone, but idea should be there. Some dodging and burning, as well as cloud overlay. Keep up the good work.
tedBalog
Sep 08, 2008 09:22 as a reply to  @ mauimau85's post |  #15
I think they would look better with some strong contrast.
5D | 24-70mm f/2.8L | 70-200mm f/2.8L IS | 70-200mm f/4L | 85mm f/1.8
6,081 views & 0 likes for this thread, 21 members have posted to it.
1604 guests, 158 members online
