Thread started 01 Sep 2008 (Monday) 20:21
Learning to use my new speedlite
paulie8pointer
Sep 01, 2008 20:21 |  #1
What should I do different with this??
IMAGE: http://img354.imageshack.us/img354/5585/img2271vj3.jpg
IMAGE LINK: http://imageshack.us  (external link)
By paulie8pointer (external link)
I hope when I die....My wife doesn't sell my toys for what I told her they cost!!:evil:
Robert_Lay
Sep 01, 2008 21:23 |  #2
The picture was taken with f/2.8 and 1/10" and an ISO setting of 200. That is too long an exposure for hand held. So, you are lucky that it is as sharp as it is. We have no way of knowing what exposure would be called for were the flash not used, so we don't know how much the flash contributed and how much the ambient light contributed.
The expsosure defined by the aperture, shutter and ISO would be exactly correct for a typical home office environment (EV 5 1/3). That leads me to believe that the speedlite is contributing very little to the image - probably enough to be considered as a token amount of fill light.
I would suggest that you look at higher shutter speeds in order to remove any possibility of ghosting due to camera movement.
I would also strongly recommend that the flash be used in bounce configuration in order to reduce or eliminate those hot spots that are so characteristics of direct flash (the hot spot at the end of the nose and the hot spots in the ear). I acknowledge that there is a possibility that you are using bounce or a diffuser of some sort, but the hot spots suggest otherwise.
Another suggestion would be to take the picture from further away with a longer lens in order to create a little more softness in the light.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
bdiphoto
Sep 01, 2008 22:31 |  #3
Robert_Lay wrote in post #6222649 (external link)
I would agree. Great advise.
30D with battery grip, 28-135 kit lens, 35-70, fifty, Tamron 17-35, Tamron 70-300.
Beseler Topcon SuperD. Fujifilm Finepix S1000 fd
www.blackdiamondimages​.com (external link)
www.myspace.com/blackd​iamondimages (external link)
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Sep 01, 2008 22:54 as a reply to  @ bdiphoto's post |  #4
To me, it looks like an outdoor shot in low light conditions. Also, the very sharp shadow lines around the lips, nose, neck, and ear (in addition to the hot spots and reflection in the eyes) suggest that the flash was direct and provided essentially all of the light. I would do as Robert suggested and use bounce lighting to soften the sharp edges. If you don't have a ceiling handy, then you can improvise with a white card or use some other bounce technique.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
paulie8pointer
Sep 01, 2008 23:14 |  #5
Yes I was outside on tripod and was meterd for the back ground with flash at 45 degrees with diffuser.....This speed lite is really making my head spin!
conkeroo
Sep 02, 2008 05:42 as a reply to  @ paulie8pointer's post |  #6
If you expose for the background at -2 stops, that will leave enough ambient light to affect the overall image. Then use f8 to keep the entire subject in focus and you can use a shutter speed of about 1/20 and adjust iso accordingly whilst using the speedlite (preferably bounced) to illuminate the subject. You can get away with using 1/20, even hand held, because the flash will freeze the subject.
Robert_Lay
Sep 02, 2008 10:09 |  #7
paulie8pointer wrote in post #6223241 (external link)
I hadn't counted on the tripod, since hardly anyone knows what that is anymore:lol:
Bob
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Sep 02, 2008 14:12 |  #8
Robert_Lay wrote in post #6225543 (external link)
So, are you just going to leave us in suspense? :lol:
Robert_Lay
Sep 02, 2008 21:18 |  #9
bill boehme wrote in post #6226917 (external link)
Ha Ha!:lol:
It's just another archaic tool that no one uses any more - just like lens hoods:lol:
Bob
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Sep 03, 2008 09:16 |  #10
Am I reading this wrong?
Which would make it more of a point source, right? So, a harder light from a greater distance, unless you're counting on some bounce from a ceiling which isn't present here.
If you had a bounce card or wall near the subject that the strobe could hit, that might help in this situation.
Robert_Lay
Sep 03, 2008 11:15 |  #11
PhotosGuy wrote in post #6232220 (external link)
Am I reading this wrong? Which would make it more of a point source, right? So, a harder light from a greater distance, unless you're counting on some bounce from a ceiling which isn't present here.
I had forgotten that I had assumed the outdoor environment. So, under those conditions, you are quite correct - backing up would not help. Backing up only helps when indoors with highly reflective and close walls and ceiling.
Bob
3,384 views & 0 likes for this thread, 6 members have posted to it.
2722 guests, 152 members online
