Thread started 02 Sep 2008 (Tuesday) 13:53
Lens for large group shot@
Matt30D
Sep 02, 2008 13:53 |  #1
What is the best lens for a large group shot? About 20 people 3 rows...inside? 17-85? 16-35? 10-22????
www.schuldtimagery.com (external link)
Gear: 5D/5DII/30D
Lens: 28-75, 85 1.8, 70-200 2.8 IS, 50 1.8, 17-40L
SoaringUSAEagle
Daddy Of The Crop
Sep 02, 2008 13:54 |  #2
How much space do you have to work with? I think something like a 24-70 would be fine. I have had great success with it during weddings.
5D4 | 50 1.4 | 85L II | 24-70L II | 70-200 2.8L IS II
twoshadows
Liquid Nitrogen
Gallery: 52 photos
Best ofs: 19
Sep 02, 2008 13:58 |  #3
What camera body? How much space? I would recommend using the longest FL you can to try and avoid the severe distortion effects of UWA/WA.
xgender.net (external link) Miss Julia Grey (she/her/Miss)
The Chronochromagraph "how to" thread
Matt30D
Sep 02, 2008 13:59 |  #4
I am a little lost in mm...24-70 is that wide angle? I want to get a 10-22? What do you think, I love extreme wide angle!@
Gear: 5D/5DII/30D
Matt30D
Sep 02, 2008 13:59 |  #5
How much is the 24-70?
Gear: 5D/5DII/30D
TeeJay
Joined Jun 2005
Sep 02, 2008 14:11 |  #6
Unless you need to shoot the group from about 6 feet away, you really dont need a 10-22 lens. You may "love" wide angle, but it really isn't the best lens for this type of shot, as the distortion it will introduce wont gain you any friends!
For groups of this size I use my 24-70 with no problems at all.
TJ
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
ducko
Sep 02, 2008 14:17 |  #7
Typically I shoot with about 70mm for portraits. I find that there isn't any distortion at that length. I went to a graduation recently and shot with my 16-35 since I was in a crowded reception hall and the distortion definitely showed.
--Ducko
Wilt
Sep 02, 2008 14:21 |  #8
[PAUSE] OP better tell everyone what camera body this lens is intended for use on!
Two of the replies come from people who have one FF and one APS-C body, and the FL choice is very dependent upon which one is owned by the OP. 24mm is not 'wide angle' on APS-C, it is 'very wide' on FF!
timnosenzo
Sep 02, 2008 14:22 as a reply to  @ ducko's post |  #9
Matt30D wrote in post #6226837 (external link)
Ultra wide angle lenses and portraits usually don't mix. Distortion tends to lead to unflattering results.
Matt30D wrote in post #6226847 (external link)
About $1200
therealmr
Sep 02, 2008 14:23 |  #10
Rent a lens, I'd say the 16-35. (I'm assuming a 1.6 crop)
Then get as far back as you can and zoom in as much as possible.
The 24-70 is pretty soft wide open.
http://www.simkinsphot​ography.com/ (external link)
TeeJay
Joined Jun 2005
Sep 02, 2008 14:28 |  #11
therealmr wrote in post #6226992 (external link)
Mine isn't
TJ
darksparkz
Sep 02, 2008 14:47 |  #12
10-22 isn't the ideal lens for group shots, it is wide as mentioned, but may distort on the ends, which would kinda stink.
The 16-35 is a fantastic lens, but fairly expensive for what you get. I'd recommend the 17-55mm f/2.8 IS, depends if your using it on a crop body or not, but the f/2.8 and IS would be great for indoor low lighting or handheld shots.
Otherwise, the 17-40L is an option too.
Stan43
Joined Nov 2005
Sep 02, 2008 15:18 |  #13
I usually shoot groups with the 35L on a FF body. That would be around 24MM on a crop.
If you want a zoom both the 17-55 EFS or the 24-70L would be good choices.
Canon: 5DSr,5Dmk3,1DXmk2 5d MK4,11-24L,35L,70-200 2.8L2,24-105L,24-70L,Sigma 24-105 Art,50 1.4 Art,Tamron SP85 1.8,Tamron SP90 Macro. Zeiss 135 F2 Milvus
Pentax 645Z,90 2.8 Macro,55 2.8,24-48 . Fuji: EX2,XT1,14mm,18-55,56,55-200,Zeis Touit 2.8 Macro
Subimatt
Sep 02, 2008 15:21 |  #14
from OPs username im guessing on a 30D. 17-55 or 24-70 would be fine.
5D2 x3,5Dc,60D,40D,16-35LII,24-70L,70-200L 2.8IS,15 FE,24LII,35L,45TSE,50Lx2,85LII,100L Macro,135L,580exII x5
BLOG (external link)
WEBSITE (external link)
Facebook! (external link)
eelnoraa
Sep 02, 2008 18:50 as a reply to  @ Subimatt's post |  #15
I will use equivalent FL so we don't need to care about body and sensor size.
Unless you have absolutely no space to back up, I suggest use no shorter than 30mm FF equivalent for group shots. Use longer FL if you can, like 35mm or 50mm. The problem with short FL is perspective distortion: People in front row will appear noticeablely bigger than people in back row. People in middle appear bigger than people on the outside. People on the outside appear to be wider (fatter) than they actaully are ..... All in all, it doesn't give a natural look.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
15,098 views & 0 likes for this thread, 15 members have posted to it.
2511 guests, 102 members online
