Thread started 01 Feb 2005 (Tuesday) 08:07
what mode do you shoot in
OceanRider
Joined Dec 2004
Feb 01, 2005 08:07 |  #1
This may sound like a silly question, but what mode do you all shoot in. Besides the obvious, like you want to show blur, freeze some action, or control the DOF--what is the best general purpose mode?
Say your shooting a wedding, do you stay on green square/ flip between the creative modes or is P and Tv Av your place of choice. Or are you are all over the map constantly.
Just curious.
Joel
Canon 20D X 2 & 580EX
Canon EFS 17-85mm f/4-5.6 IS USM
Canon EF 75-300mm f/4-5.6
Canon EF 50mm f/1.8 II
LumiQuest Pro Max; Omnibounce; Newton Di100CR
Ikinaa
Joined Jul 2003
Feb 01, 2005 08:36 |  #2
On the 20D, I'm on P when shooting inside with flash because I think that the cam handles this very well alone ;-)a
Without flash I use mostly AV so I have more control over DOF
When taking nightshots, I use M
www.ikinaa.net (external link)
aam1234
Joined May 2004
Feb 01, 2005 08:41 as a reply to  @ Ikinaa's post |  #3
Av 99.9%.
steven
Joined Jul 2004
Feb 01, 2005 09:02 |  #4
Manual 99.9%
Takes some work to become acustome to the dial to set apature and shutter speed but in the end is more than worth it. You can easily make exposure compensation without use the EC function, You can use your own experience when presented with a picture that would normally "fool" you in camera meter and adjust accordingly.
I'm just a fan of manual mode:)
1Ds
Canon Lens
16-35mm L, 24-70mm L, 28-135mm IS, 50mm II, 70-200mm L ISf2.8, 100mm Macro, 100-400mm L IS
Sigma Lens
180mm Macro
iwatkins
Joined Sep 2003
Feb 01, 2005 09:03 |  #5
All over but rarely stray past the P into "auto" modes.
lmelendez
Joined Dec 2002
Feb 01, 2005 09:08 as a reply to  @ aam1234's post |  #6
aam1234 wrote:
Av 99.9%.
Same here....
http://www.bluejaygall​ery.com (external link)
neutral
Joined Oct 2004
Feb 01, 2005 09:30 |  #7
M 99% of the time.
Vegas ­ Poboy
Joined Aug 2003
Feb 01, 2005 09:33 |  #8
99% of the time is Manual for me. It helps bring out the creativity & techie side for me.
$$$ in Canon Gear & Lighting Equipment
KevC
Joined Jan 2005
Feb 01, 2005 09:35 |  #9
M. Always. Though when I start shooting weddings I'd switch to Av for the hectic times... :)
Too much gear...
take nothing but pictures .... kill nothing but time .... leave nothing but footprints
OceanRider
Joined Dec 2004
Feb 01, 2005 10:51 |  #10
Thanks guys thats awesome to know!
Joel
Jesper
Joined Oct 2003
Feb 01, 2005 11:08 |  #11
I use Av most of the time, because it gives me control over the aperture, which determines the depth-of-field. I often use partial metering and meter the brightest part of the area and apply some + exposure compensation. Remember that the camera will set the exposure so that what the meter reads will be average gray in the image. So if you meter on a bright part with the partial meter, you should use for example +1 1/2 to +2 exposure compensation to make sure that the bright part will be 1 1/2 or 2 stops brighter than average gray.
When I use flash as my main light source, I set the camera to M, the shutter speed to 1/200 and I set the aperture to get the desired DOF. When using flash, the shutter speed isn't very important. On the 10D, 1/200 is the fastest shutter speed that can be used when using flash. See Flash Photography with Canon EOS Cameras (external link) for everything you want to know about flash photography.
Show blur: Use Tv, choose shutter speed 1/60 or slower (depends on the amount of blur, speed and distance of the subject). You might need IS or a tripod for really slow shutter speeds.
Freeze action: Use Tv, choose shutter speed at least 1/200 (again, depends on speed and distance of subject).
Control DOF: Av, because aperture setting controls DOF.
Green square?! Never!!! :rolleyes: I don't want the camera to think and make decisions for me.
Canon EOS 5D Mark III
Blackbird
Joined Jan 2005
Feb 01, 2005 11:12 |  #12
Tv mainly, or Av if I want more control depth of field.
EOS 20D
EF 28mm f1.8 USM
EF 90-300mm USM.
17-40mm f4L :)
430EX Flash
Chris ­ P ­ Bacon
Joined Jul 2004
Feb 01, 2005 12:37 as a reply to  @ Blackbird's post |  #13
Manual 99% for me, av or tv if the subjects something quick so I don't have to think about any settings, just composition.
tim
Light Bringer
Feb 01, 2005 12:53 |  #14
Maybe you should add a poll?
I shoot in Av 90% of the time, and full manual when i'm using a flash or doing close macro work.
ssim
Joined Apr 2003
Feb 01, 2005 13:56 as a reply to  @ tim's post |  #15
AV about 95% of the time.
3,382 views & 0 likes for this thread, 25 members have posted to it.
2022 guests, 103 members online
