Thread started 03 Sep 2008 (Wednesday) 11:05
Better Beamer problems
paulie8pointer
Sep 03, 2008 11:05 |  #1
Is there a trick to using the Better Beamer? I have been using it to photo ducks and geese (In flight and in water) Problem I'm having is bad red eye or the eyes look like bright white lights. Would the problem be solved if I got flash off camera and onto bracket?? I am using it with my 100 -400 on 40d and 580 flash. Anyone know what I should do?? Also during the day with BIF should I use high speed sync and a faster shutter speed than the 250 that the camera defaults to?? Thanks for any help - Paulie
I hope when I die....My wife doesn't sell my toys for what I told her they cost!!:evil:
stargazer77517
Sep 03, 2008 11:12 |  #2
I have my flash and beamer off camera on a flash bracket extender. I was having the same problem until I raised it up 6 to 8". I have the Xsi and as for the sync, I can not get a shutter speed of higher than 1/320 or the flash will not cover the whole frame, any thing less its ok. Dont know about the 40D though.
Davis (Fred)
My Gallery http://davisbourque.ze​nfolio.com/ (external link)
paulie8pointer
Sep 03, 2008 11:20 |  #3
Stargazer - What bracket do you use? Are the results much better? Thanks
stargazer77517
Sep 03, 2008 11:48 as a reply to  @ paulie8pointer's post |  #4
Well I looked at all the high dollar mounts (Wimberly, Jobu, RRS) and such, but I didnt want to spend a fortune to get a set up like that so I ended up making one. I used one of these http://www.bhphotovide​o.com …93_Heavy_Duty_G​imbal.html (external link) and I had one of these http://www.bhphotovide​o.com …0_700_Pro_RL_Br​acket.html (external link) and made one. Ill take a pic of it tonight and post it here tomorrow. As for the results, it works great. No problem with red eye at all. Set the flash per the instructions on the Better Beamer (50mm max) and raise it to what ever level I want and go for it.
Davis (Fred)
PacAce
Joined Feb 2003
Sep 03, 2008 13:25 |  #5
paulie8pointer wrote in post #6232861 (external link)
Since I shoot birds with the camera in Av mode, I always have my flash set to HSS mode so that I won't have to worry about the shutter speed being too slow for the aperture I've selected when using the flash. You do loose about two stops of light in HSS mode (compared to non-HSS mode) but the flash is only being used for fill so that's not really a big deal. Having some light for shadow fill is always better than none.
...Leo
paulie8pointer
Sep 03, 2008 13:34 as a reply to  @ PacAce's post |  #6
Thanks guys for the help and Stargazer I'd like to see your setup -
stargazer77517
Sep 04, 2008 07:29 as a reply to  @ paulie8pointer's post |  #7
Here ya go. I figured I built this for 250.00 since I had the Stroboframe already. Here are the pieces, the frame came from B&H.
I drilled holes in the Stroboframe to match the ones in the bracket. These were 6 mm holes so I went to the hardware store and bought 2 6mm bolts 1 1/2 inch long and 2 plastic knobs
Cut the bolts to the size I needed and JB welded the plastic knobs to the bolts.
This shows how the bracket and frame fit together.
and the finished product. The top half of the lens bracket moveds up and down and the whole thing moves side to side, With the bracket mounted as such to the top half, the flash is always pointed to the same place as the lens.
Its a poor mans version but, it works just fine for me. And I didnt spend 500-600 dollars to get-r-done.:lol:
Hope this gives ya some ideas.
Fred
Davis (Fred)
PacAce
Joined Feb 2003
Sep 04, 2008 08:25 |  #8
Neat mod! :)
This is the first time I've actually seen someone using the 3421 with the camera/lens hanging from the top. How stable is it when used that way, especially with a flash bracket attached to it? Just curious.
...Leo
stargazer77517
Sep 04, 2008 08:30 as a reply to  @ PacAce's post |  #9
Once you get it balanced, works pretty good. I can take my hands off of it and it will stay put, although I have only used it a couple of times so far. Now with a lens that extends as it zooms its a bit tricker but still doable
Davis (Fred)
1,505 views & 0 likes for this thread, 3 members have posted to it.
2898 guests, 137 members online
