Thread started 03 Sep 2008 (Wednesday) 12:01
poor lighting, solutions?
DragonDan
Sep 03, 2008 12:01 |  #1
This was taken after dark, in a park area that had those crummy yellow energy-efficient lights. I didn't use a flash. Any ideas on how I could have made a better exposure?
full size pic at:Clicky piccy (external link)
Canon EOS 50D gripped; Tokina 11-16mm f/2.8; ∑30mm f/1.4; ∑105mm macro; 70-200mm f/4L; 430EX II
hawkeye60
Sep 03, 2008 12:14 |  #2
I used a levels adjustment layer, and a hue and saturation layer in PS to get to this:
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
kirkt
Sep 03, 2008 12:33 |  #3
Next time:
1) use a flash if possible.
2) if no flash, increase the ISO (here it was 800 - depending upon your camera, you may be able to go to 1600 or even 3200).
3) set the white balance properly for the lighting (tungsten or incandescent in this case).
4) if you do not have an IS lens (image stabilizing) or some such function on the camera, use a tripod or steady yourself against a wall or column and tuck your arms against your side to stabilize the camera to counter the long shutter speed necessary for the low light. You can also try to open the aperture if possible (although here it looks like it was full open at 1.8 ), but this will affect your DOF and may throw parts of the subject out of focus.
5) in low light, the AF may not be able to lock properly, so you may need to focus manually - some hotshoe flash units (Canon Speedlights, for example) may help you with AF assist beams.
6) shooting RAW may also help with post-processing adjustment.
Good luck - a lot of us have been there with this shot for sure.
Kirk
Kirk
nwa2
Sep 03, 2008 12:46 |  #4
In addition to Kirkts' great advice:
Good points - you were using your nifty, wide open.
Bad points - Your shutter speed was 1/20, way to slow unless you were on a tripod. Looks like the focus has locked onto the candle, try a different focus technique.
You were using a 350d, you could have gotten another stop by racking the ISO upto 1600.
Canon 6D; 7D; 40D:
There are many tomorrows', but only one today!!
[SIZE=1][COLOR=Black]http://www.Abercrombie​.me.Uk (external link)
http://imagesix.wordpr​ess.com/ (external link)
Robert_Lay
Sep 03, 2008 21:26 |  #5
Under the kind of lighting you were under the only safe way to get the color balance right is to shoot a gray card and use it for a Custom White Balance following the procedure for your camera. Barring that, the least you can do is shoot RAW so that the Color Temperature and Tint can be corrected under better conditions.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
DragonDan
Sep 04, 2008 10:17 |  #6
Thanks all for the information. I did recently switch over to shooting RAW only. Probably just because I'm a control freak. Hawkeye did do a better job of removing most of the yellow haze. Seems I need to buy a gray card and throw it away as soon as I calibrate my palm!
JoYork
Sep 04, 2008 10:30 |  #7
I thought that calibrating your palm (nice expression btw) was for exposure, not colour balance?
Jo
kirkt
Sep 04, 2008 12:44 |  #8
I can see placing a gray card in front of the birthday cake while everyone is singing and the baby wants to grab a handful of icing as being a great party stunt! Good luck with that. :)
Kirk
Kirk
Robert_Lay
Sep 04, 2008 16:13 |  #9
JoYork wrote in post #6239616 (external link)
You are quite correct. This is a situation in which one of the dual purposes of the 18% Gray Card has been mis-applied. Gray cards are used both for color balance problems and for placing a Zone V exposure. The former is concerned primarily that there is no color cast, whereas the latter depends upon tonal value or brightness of the 18% grey card.
If you are trying to get a perfect color balance in your scene, the Custom White Balance feature in the camera can do that for you.
*************Gray Card***************
Tutorial on Use of the Gray Card for Exposure and White Balance:
http://www.zaffora.com​/W9DMK/GrayCardTutoria​l.htm (external link)
or the downloadable PDF version:
http://www.zaffora.com​/W9DMK/GrayCardTutoria​l.pdf (external link)
Bob
griptape
Sep 04, 2008 17:18 |  #10
Your biggest problem (aside from the obviously horrible white balance) is that you completely missed the focus. The hand on the candle is perfectly in focus, and the child is just blurry background.
brecklundin
Sep 04, 2008 17:40 |  #11
DragonDan wrote in post #6233185 (external link)
I took a different tact. Opened in CS3, cropped the image down, selected this leetle angel's head and did some USM sharpening. Then saved as TIFF, Opened in LR1.4, I adjusted vibrance and saturation, adjusted clarity then ADDED the vignetting (both sliders all the way to the LEFT.)
Not sure if it's the look you wanted but I just thought I would have a whack at salvaging this pic...
Real men shoot Pentax because we're born with our own Canon's!!
{Ok...ok, some of use just have a PnS but it it always makes me happy! :D}
Pentax K5, K20D, Three Amigos (Pentax FA 31/1.8 Limited Silver, Pentax FA 43/1.9 Limited Silver, Pentax FA 77/1.8 Limited Silver), Pentax DA 35mm F2.8 Macro Limited, Sigma 24-60/2.8
symes
Sep 04, 2008 18:09 |  #12
Convert it to B&W... :)
Symes
Symplicity Photography (external link) Symplicity Glamour (external link)
5D Mark II; 1D Mark II; 17-40L; 24-70 2.8L; 70-200 IS 2.8L
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Sep 04, 2008 22:40 |  #13
It is.
Need an exposure crutch?
Great. You have what looks like a white tray there that you could try to use to correct the WB. Thing is, the "Correct" WB may not be the "Right" WB for a image. Remember, you're the judge of your own image, & people expect that an image using a candle flame will be on the warm side of "Correct".
Brownie127
Sep 06, 2008 11:30 |  #14
Focus on the eyes next time. Your shot puts focus on the candle and detracts from the subject.
You did right not to use flash. Flash would have killed the effect from the candle and glow on the subjects face. The suggested crop and white balance makes a perfect picture.
Barry in UK www.cerity.eu (external link)
michillebaker
Sep 06, 2008 22:49 as a reply to  @ Brownie127's post |  #15
Here is my take at it my take on your photo. I hope you like. I thought it would look better in black & white.
IMAGE: http://i445.photobucket.com/albums/qq172/mrsbaker82/HighKeyBW-2.jpg
Not a pro by any means.. Just enjoy taking pics.
Gear: Canon 60D, Rebel XSi; Canon 50mm ; Canon 55-250mm IS ; Flash: Canon 430ex II with diffuser My Just order sigma 18-50mm :).
My Photo Blog (external link) ; My Actions & Tutorial Blog (external link) ; My flickr (external link)
http://michilles-photography.blogspot.c​om/ (external link)
3,044 views & 0 likes for this thread, 14 members have posted to it.
931 guests, 146 members online
