TwistedGray wrote in post #6288912
You can see it from the road right?
I saw this on the site:
No, you cannot see anything from the road. As you aproach the waterfall area, there is a parking area on the left which is a small road which takes you into a palking lot. Then there is a short trail you have to walk down under the freeway and then you will see the falls below the freeway. There is also a small area on the right before the parking area that you can pull off on and view the falls from the highway level, but you must get out of your car to view the falls because you are above the falls looking down, just as my shot shows. All photos of this shot are taken from the highway level or from the trail level which is maybe 30 or 40 feet lower. I have seen none from beach level. Hope this helps
