Thread started 03 Sep 2008 (Wednesday) 18:00
How to Light a Helicopter
splitfyre
Joined Jan 2005
Sep 03, 2008 18:00 |  #1
Need suggestions on lighting a helicopter. Looked at what Joe McNally did when he lit a firetruck in NY. I'm looking to light up the inside of the helicopter. Thinking of using multiple 580 EXs and EXIIs.
Thanks in advance. Just looking at a few ideas. :)
- Kev
Digital: Canon 5D2,5Dc,40D
Film: Yashica FX-2
Lenses: Canon 35L, 50 1.4, 85 1.8, and Canon 135L
DDCSD
GIVIN' GOOD KARMA
Sep 03, 2008 18:02 |  #2
What exactly do you have available for lighting?
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Sep 03, 2008 18:03 |  #3
Only thing that comes to mind right away is that you'll definitely need radio triggers. In small spaces when you need light from back of the camera and when you want to hide light sources infrared just does not work.
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
splitfyre
Joined Jan 2005
Sep 03, 2008 18:05 |  #4
mmm ok.
Film: Yashica FX-2
FlyingPhotog
Cream of the "Prop"
Sep 03, 2008 18:08 |  #5
<Subscribing Out of Curiosity...>
Jay
PhotoJourno
High Plains Chimper
Sep 03, 2008 18:09 |  #6
I usually try to follow the lighting patterns used from design. In the case of a chopper, depending on the model, I would try to use a hi-power light source directly behind the bubble (Say an old Hiller, of the low model Bells) pointing almost upwards, as centered on the console as possible. Easier to get away with this, if instead I have a divided windshield to work with.
In the case of the Bell 200 type aircraft, where the head and foot window panes are located, the most natural lighting is obtained by putting light sources relatively close to those areas.
Cables should not be a huge issue if the setup is well coordinated, and with a safety person handy you can route the cables towards common areas of the ship that are not visible from the camera POV and down to the ground via skids.
There ya have it, for whatever's worth.
It really depends on what effect you are trying to achieve.
--Mario
"Sensa luce non si vede nessuna cosa"--Lorenzo Ghiberti
tim
Light Bringer
Sep 03, 2008 18:12 |  #7
Taking out seats and unnecessary equipment, and not filling the tanks will lighten a helicopter.
Microcosm
Sep 03, 2008 18:14 |  #8
Check this:
http://strobist.blogsp​ot.com …t-night-chopper-pt-1.html (external link)
and this:
http://strobist.blogsp​ot.com …t-night-chopper-pt-2.html (external link)
I knew I had read about this somewhere before so I googled strobist and helicopter and I found the article. It was interesting to read, anyway hope that helps.
All Gear| Canon 50D | Canon Rebel XTi | EF 17-40mm f/4 L | EF 24-105mm f/4 L | EF 70-300mm f/4-5.6 IS | EF 50mm f/1.8 | EF-S 18-55mm f/3.5-5.6 | 580EX II
Nikon EM | 50f/1.8 | 100 f/2.8 | Speedlight SB-E
MyFlickr (external link)
splitfyre
Joined Jan 2005
Sep 03, 2008 18:31 |  #9
Thanks Microcosm.
Film: Yashica FX-2
LBaldwin
Sep 05, 2008 07:18 |  #10
OK there are a few safety items first,
Is the A/C going to be operational during the shoot? If so we a have a few items to consider. If the A/C is stationary and without power, then all is cool. But the minute you fire up the radios and nav gear you chance damaging it with any radio interferance from the cameras systems. Both IR, as well as radio can have a negative effect and so you must be very careful. My first stop would be to talk with the A/P mech that services this specific A/C and make sure that there are no issues.
Second is make sure that if the A/C is to me moved or operated in any way that you plan your shoot and put it on paper and openly discuss everything with both the owner and pilot. Communication errors can cause serious injury and death or destruction and damage to property when no plan is in place and not everyone is on the same page.
I saw video of a pilot that was inspecting an A/C prior to purchase. He got to the strip and jumped in the A/C only to learn the hard way that the engine did not have oil in it yet....
Les Baldwin
http://www.fotosfx.com (external link)
1,256 views & 0 likes for this thread, 8 members have posted to it.
Latest registered member is Miss Understood
477 guests, 178 members online
