Thread started 04 Sep 2008 (Thursday) 18:58
Kenko Tubes
reneethomas
Demoted and banished by the TF
Sep 04, 2008 18:58 |  #1
I received my kenko tubes today and I cannot seem to get them to work with any EF lens. I have no idea if I am doing something wrong or I got defective tubes. Any suggestions in case of user error? Thanks!
Racquel is my real name
Gear List Flickr (external link) BugGuide (external link)Facebook (external link)
troypiggo
Sep 04, 2008 19:01 |  #2
Which Kenko tubes did you get? What do you mean by "cannot seem to get them to work"? Do they mount on camera? Do the lenses mount on the tubes? Is it just that you can't focus on something? Is autofocus not working?
"Interesting. You're afraid of insects and women. Ladybugs must render you catatonic." - Sheldon
Flickr (external link) | Gear List | Macro Rig | Astro Rig | Astro Software Post
reneethomas
Sep 04, 2008 19:04 |  #3
troypiggo wrote in post #6242604 (external link)
I can mount them just fine but the auto focus nor manual focus will work. I cannot make anything out in though them, it is just fuzzy.
I purchased the Kenko 3 ring set for Canon EOS.
S-S
frustrating simple something
Sep 04, 2008 19:05 |  #4
i find that sometimes the camera needs to be turned off before the tubes & lens are attached, in order to electronically recognise the lens (for the aperture to work)
when you say everything is fuzzy... you might be too far away from the subject. tubes mean you need to get VERY close... almost touching with the longer tubes. and dont bother with AF... use MF or zoom ring to focus, or move the camera slightly unil the point of focus is correct thru the VF. if your camera has live view, this is where it comes in handy.
i basically only use my tubes with my 50mm f/1.8... zoom is basically useless at those tiny distances
you will prolly need to drop your aperture a little as well if you are used to shooting wide open, otherwise the focal plane will be far too thin
troypiggo
Sep 04, 2008 19:10 |  #5
The behaviour of tubes will vary depending on the length and number of them you use, and also what lens you're using on them.
You realise that you lose infinity focus? Basically what they do is just put more distance between the lens and sensor/film, allowing the lens to focus closer than the bare lens. It is possible that if you're using too many tubes, the focal point is just millimetres in front of the lens.
Try just one of the short tubes with your lens and see how that goes.
Do the tubes have electrical contacts on them? Like the ones on your lenses? If so, you'd assume AF should work. I don't understand how MF "can't work", that's in your hands ;)
reneethomas
Sep 04, 2008 19:16 as a reply to  @ S-S's post |  #6
Okay I feel stupid :oops: I was not close enough. Okay I am off to find a pile of sand to stick my head in. Thanks for helping the dummy!!
S-S
Sep 04, 2008 19:20 as a reply to  @ reneethomas's post |  #7
dont be silly - we all have to learn! glad it was such a simple fix, post some of your macro shots here to show us :)
troypiggo
Sep 04, 2008 19:26 |  #8
No worries. The only stupid question is an unasked one.
Glad it's sorted. :)
tin.risky
Sep 04, 2008 20:07 |  #9
No worries. The same thing happened to me the first time I used tubes. It took me a minute or two to figure out that I just wasn't close enough.
Simoli
Sep 04, 2008 22:47 |  #10
reneethomas wrote in post #6242674 (external link)
I still have my box of sand left over from when I had the same "issue", you can borrow my box.
Jim (external link)
www.simoli.net (external link) || Gear List
Familiaphoto
Sep 05, 2008 11:33 |  #11
Don't feel bad, I did the same thing when I first got mine.
Paul
Blog (external link) | Gear (external link) | Gallery (external link)
Bag Reviews: Domke F-3x | More to come...
reneethomas
Sep 05, 2008 11:46 as a reply to  @ Familiaphoto's post |  #12
Well this is my first attempt with the 36mm tube. Not the best shot but at least I can get something..lol
I am going out today to play more with the tubes so I will let you know if I get anything worthy of posting.
JohnJ80
Sep 05, 2008 20:10 |  #13
Also, it's very important to make sure you fill the tubes with L grade air.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
Point-n-shoot-n
Sep 05, 2008 22:06 |  #14
JohnJ80 wrote in post #6250104 (external link)
J.
Now that is just plain funny!:lol:
Canon 5D mk IV, Canon 5D mk iii, Canon 5d classic, Rebel XTI 400D 18-55 kit lens, Canon EF 85mm 1:1.8, Canon EF 17-40 F4L, Quantaray 70-300 1:4-5.6 LD, Canon 70-200 F2.8 iiL, Canon EF135 F2 L, Canon 200 F2 L, Tamron 28-75 1:2.8 , 2 alien bee 800's, 430 EXii, 580 EXii, rectangular and octo softboxes, assorted umbrellas, portable backdrops, radio triggers and still adding.............
S-S
Sep 05, 2008 23:17 as a reply to  @ Point-n-shoot-n's post |  #15
L grade air is incompatible with kenko... severe malfunctions in air optics may occur ;)
2,583 views & 0 likes for this thread, 8 members have posted to it.
Kenko Tubes
2704 guests, 151 members online
