Thread started 04 Sep 2008 (Thursday) 22:46
Guide Number(s) and 580ex2
rohicks
Sep 04, 2008 22:46 |  #1
Ok sorry if seems like a dumb question, but i was taught when i was young that there isn't a dumb question :lol: .
Anyways, I know the max GN for the 580ex2 is 58 at 105zoom.
I read that it is also 28 at 28 zoom.
How do i figure out what the GN is at different zooms?
Is there a formula for it?
Thanks in advance.
Ryan O. Hicks
Portfolio (external link) - 500px (external link)
flickr (external link) - Dribbble (external link)
twitter (external link) - facebook (external link)
Titus213
Sep 04, 2008 22:54 |  #2
Don't know about a formula but here's a link to the info.
http://photonotes.org …580exii&flash2=​*&flash3=* (external link)
Dave
Perspiring photographer.
rohicks
Sep 04, 2008 22:58 as a reply to  @ Titus213's post |  #3
Thank you so much.
Ryan O. Hicks
PacAce
Joined Feb 2003
Sep 05, 2008 06:58 |  #4
The guide numbers can also be found in the flash owner's manual.
...Leo
ST87
Sep 05, 2008 07:41 |  #5
GN is typically measured with distance (so you sometimes have it in metres or feet). Basically when you "zoom" out with the flash, the light will not be as concentrated on one spot as it is on the 105mm setting, hence the light will travel much further in comparison to your light being spread out for a 28mm setting.
Most specifications are something like 58m @ 105mm (ISO 100). This means that you can get a correct exposure if your subject is 58 metres away from your camera with (ideally) no ambient light (ok maybe it's not that realistic if you can focus so far away in a dark room, but these are just measurements here), provided that you are on a 105mm setting on your flash and also that you are using ISO 100.
Why you don't see this in practice is that the measurement is based on an F-stop of 1. So if you were using an f-stop of 4, and you are flashing directly, then place yourself no more than 14.5m away. Also, the GN will increase linearly as you increase your ISO.
Hope this helps ;-)a
rohicks
Sep 05, 2008 10:03 |  #6
ST87 wrote in post #6245688 (external link)
Well i already knew all that ;) ... but thanks anyway.
PacAce wrote in post #6245531 (external link)
Yah, i just don't have access to my manual right now.
I forgot about checking photonotes.
oh well thanks again.
Ryan O. Hicks
1,431 views & 0 likes for this thread, 4 members have posted to it.
2880 guests, 137 members online
