mrsmac wrote:
Hi all - this is slightly off the topic, but I want to make a slide show of my G3 digital photos, with a musical background for my rellies to play on their TV, through their DVD. What is a good software program I could use?
I have Nero 5. That didn't seem to work. I looked at a trial version of Ulead CD & Picture 3 - it seemed a bit clunky and not all that cheap...
Any suggestions would be welcome!
Cheers
Mrs Mac
Hi MrsMac, I have tried many, but this was recommended to me about 10 days ago.
I needed the prog with the MPeg2 plug in at $49.99. IT REALLY WORKS.
I took 130 shots of my friends Golden Wedding Celebration. I have added them and added music. It gives the full length (in minutes) of the slideshow and you then add tracks to be as near as possible to the slideshow length. Click on Automate and the music matches to the very end of the slideshow.
I also have nero and I chose use nero drivers and then "start" to burn. It plays on our tv and another friends through the dvd player.
I should say you need to choose dvd (it gives options for svcds and vcds).
BTW you can download a full evaluation copy. I burned mine to DVD rewriteable discs to make sure it was ok and would play on the tv.
You still get "Evaluation copy" across it until you pay, but it is worth giving it a try. The transitions and panning are excellent.
Hope this helps.
http://www.picturetotv.com/
