Pretty much what the title says...for those out there that use a Graduated Neutral Density filter how do you meter the scene.
What's your technique?
Thanks!
grizzy Senior Member 877 posts Likes: 20 Joined Nov 2006 Location: Tampa, Fl...native! More info | Sep 05, 2008 07:25 | #1 Pretty much what the title says...for those out there that use a Graduated Neutral Density filter how do you meter the scene. http://cwwayne.zenfolio.com/
jdizzle Darth Noink 69,419 posts Likes: 65 Joined Aug 2006 Location: Harvesting Nano crystals More info | Sep 05, 2008 08:42 | #2 I usually meter for the foreground.
karfeef Senior Member 333 posts Joined Dec 2005 Location: Liverpool More info | generally you would take a reading from the forground, and the sky, work out how many stops difference there is, and choose a ND grad to suit - and then use the settings for the forground. that should give you a perfectly exposed image all across. Canon 500d | Canon 28-135mm IS USM | Canon 50mm 1.4 | Canon 18-55 IS Kit | 2x Canon 430ex
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Sep 05, 2008 09:19 | #4 I use manual mode and meter off the histogram - I use the foreground as a starting point. Gear Listhttp://www.codastudios.com.au
grizzy THREAD STARTER Senior Member 877 posts Likes: 20 Joined Nov 2006 Location: Tampa, Fl...native! More info | Sep 05, 2008 10:05 | #5 So are all you obviously metering without the GND on? http://cwwayne.zenfolio.com/
jdizzle Darth Noink 69,419 posts Likes: 65 Joined Aug 2006 Location: Harvesting Nano crystals More info | Sep 05, 2008 11:16 | #6 Yes meter without the GND first. Than do the reading for the sky and foreground and determine the number if stops. If it's apporximately 2 stops, use a 2 stop filter. If it's 3 stops use a 3 stop filter. I usually use a 2 or 3 stop GND most of the time.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Sep 05, 2008 12:18 | #7 Jim G wrote in post #6246231 I use manual mode and meter off the histogram - I use the foreground as a starting point. Ditto. After a while, you'll get pretty adept at just metering the scene in your head...it becomes second nature. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
wallybud Taking the "Walk of Shame" 2,980 posts Likes: 1 Joined Feb 2008 Location: Buffalo, NY More info | Sep 05, 2008 19:42 | #8 argyle wrote in post #6247341 Ditto. After a while, you'll get pretty adept at just metering the scene in your head...it becomes second nature. As far as figuring the number of stops difference between foreground and background, and then selecting a matching filter...be careful when doing this. The sky is always brighter than the foreground...using a 3-stop filter with 3-stops difference will end up with the fore/back looking the same as far as intensity goes. I'll generally pick a filter that's one stop less than the difference to ensure that the sky stays brighter (as long as I don't blow anything out). +1 -Walt-
| Latest registered member was a spammer, and banned as such! 2704 guests, 151 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
