Just curious what you guys use as the semi-reflective flooring that is often used with white backgrounds? Is it just something that I can pick up at home depot or is it something more photography related?
Sep 05, 2008 15:32 | #1 Just curious what you guys use as the semi-reflective flooring that is often used with white backgrounds? Is it just something that I can pick up at home depot or is it something more photography related? 5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
whiskaz Goldmember 1,503 posts Joined Apr 2006 Location: Parkersburg, WV More info | Sep 05, 2008 15:34 | #2 White Tile Board from Home Depot (Bathroom section) works pretty well for white (it's white). I use 2 pieces. About $11.00 a sheet... Jeremy | Gear List | EyeDigress - A Photoblog
Sep 05, 2008 15:39 | #3 whiskaz wrote in post #6248517 White Tile Board from Home Depot (Bathroom section) works pretty well for white (it's white). I use 2 pieces. About $11.00 a sheet...
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | Sep 05, 2008 15:44 | #4 carpenter wrote in post #6248545 thanks do you know how big they are? I assume I will be needing a truck. .. what about black? Get a piece of glass or plexiglass. It reflects more and works with any color background. -- Ken
whiskaz Goldmember 1,503 posts Joined Apr 2006 Location: Parkersburg, WV More info | Sep 08, 2008 14:01 | #5 carpenter wrote in post #6248545 thanks do you know how big they are? I assume I will be needing a truck. .. what about black? It's 4'x8' ... flexible enough that I got 2 sheets into the back of a 4Runner (curved into the backseats). Jeremy | Gear List | EyeDigress - A Photoblog
hawk911 Cream of the Crop More info | Sep 08, 2008 15:24 | #6 whiskaz wrote in post #6248517 White Tile Board from Home Depot (Bathroom section) works pretty well for white (it's white). I use 2 pieces. About $11.00 a sheet... +1 on that. I might try the plexi though. I want to use more than just white for my shoots. HAWK Photography Gallery
whiskaz Goldmember 1,503 posts Joined Apr 2006 Location: Parkersburg, WV More info | Sep 09, 2008 10:43 | #7 Yea, plexi works. I've used it for black. It's pricey though. For white backgrounds, like the OP mentioned, tile board is excellent... big and cheap. Jeremy | Gear List | EyeDigress - A Photoblog
| Latest registered member was a spammer, and banned as such! 2866 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
