Thread started 05 Sep 2008 (Friday) 19:32
400 5.6L lens collar
silverwolf
Sep 05, 2008 19:32 |  #1
Hello has anybody ever had any problems with this collar.I was out shooting one day with it, i felt it was loose i tried tighten it up and the knob fall right out of it.
i seen a notch on the collar itself and it looked like it was worn, worn soo bad it will not tighten up now on the lens.I sent canon a couple of messages about it and they said buy a new one or send it to be repaired.
What is your advice on this.and i think it was my fault by over tightening it, what would you think and how to prevent it next time.thanks Sean .L
One world one camera ton of L glass your creation your memory.
Sean's Gear 40D BG-E2N Grip l 400D XTI Canon Zoom's 10-22 l 18-55 l 28-135 Canon Prime's 50 1.8 l 400 5.6L Gitzo GT3540XLS
silverwolf
Sep 06, 2008 19:39 |  #2
Can anybody help me out?
Mark
Dammit I need sleep
Sep 07, 2008 00:51 |  #3
That sucks, how old/ used was it?
Mark
silverwolf
Sep 07, 2008 19:35 as a reply to  @ Mark's post |  #4
Its about a year old, i didnt use it that much.Sean .L
jdkeck
Sep 07, 2008 22:49 |  #5
I just got the same tripod mount for a 70-200 f/4. It loooks like the screw is retained by an e clip and washer. And then there is a spring. If the e clip came loose, the screw would probably come loose if loosened all of the way. You are most likely missing some key parts.
You may be able to salvage the collar by using a different screw to tighten the hinged strap of the collar. It wouldn't looks as "pretty" but it may function as intended. You may have to do some drilling and tapping.
Cheers,
Jeff
Life is not measured by the number breaths we take but by the moments that take our breath away.
silverwolf
Sep 08, 2008 19:47 as a reply to  @ jdkeck's post |  #6
Thanks jeff i will look into that.Sean .L
dekalbSTEEL
Sep 08, 2008 21:01 |  #7
http://cgi.ebay.com …eName=STRK:MEWA​:IT&ih=002 (external link)
Grippy 30D, Tokina 300f4, Sigma 18-50f2.8, Canon 70-200f4L, thrifty50mkI, PM7500DX
Jon Gee Photography.com (external link)
silverwolf
Sep 10, 2008 10:41 |  #8
Well i fixed my collar today YAY:D this makes me soo happy now i dont have to buy another one.All i did i drilled another hole for the set screw and i tightend the center cap in and bingo works like the day i got it.Thanks Sean .L:D
1,183 views & 0 likes for this thread, 4 members have posted to it.
1014 guests, 107 members online
