mestes wrote in post #6253437
well this was an away game so not the usual field, next week, I will try using a lower iso and also maybe a bit more FEC on the flash
Matt Estes - You're already at + 1 2/3 FEC so I can't imagine your flash needs more output. FWIW, I've never had to go that high when I've shot in ETTL. Lowering your ISO might get your flash further above ambient, but I'm skeptical that this will solve the issues here.
You might be at the limits of your camera's AF, but like I've said before, I wouldn't be so quick to dismiss the hardware. I shot night HS football for an entire season with an XT and a Sigma 120-300 f/2.8, so you ought to be able to do better than this. What AF scheme are you using? I'd also consider shooting your flash in manual as ETTL isn't the most reliable when it comes to getting the flash levels correct. It may be under-powering your flash which would limit the ability of the flash to freeze the action.
Have you shot day football with good results? Have you tried shooting ambient light (no flash)? When images are consistently OOF using a rig that otherwise produces acceptable results, it's almost always some sort of operator error. No offense intended.
I'd put the camera in single center point AF (evaluative metering) and AI Servo. Take it off high speed burst and put in in One Shot.
Also, I'm not sure what this means (from your EXIF):
Flash = Flash fired, compulsory flash mode, red-eye reduction mode
Is that something that is set in the camera or on the flash? I've never seen it before.
Also, the settings we're discussing here should work at any field, so returning home won't, unfortunately, be the panacea you're hoping for.
Try this. Go into a room after dark with your camera set up just like you have used it to take night football shots. Try to photograph moving things (like dogs, cats, people). Turn on enough light to allow you to aim through the viewfinder. How does this work?
Night football is pretty challenging so don't despair. Keep practicising.
