Do they have any real use, apart from snapshots?
Brainstormer Member 38 posts Joined Aug 2008 Location: Edinburgh (Scotland) / Peterborough (England) More info | Sep 06, 2008 04:59 | #1 Do they have any real use, apart from snapshots? Canon EOS 7D / Canon EOS 450-D / Canon Powershot A650 IS
noodle_snacks Senior Member 258 posts Joined Jul 2008 More info | Sep 06, 2008 05:03 | #2 fill flash outdoors, getting catchlights in dull lighting, can work alright for macro with something to diffuse the light, optical triggering of other strobes.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Sep 06, 2008 06:15 | #3 Um.... I used it once when I was messing about with friends and didn't take a flash... but they're really "just in case" devices for me. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
oldcholo Member 73 posts Joined Jun 2008 Location: Los Angeles More info | Sep 06, 2008 07:01 | #4 it works just fine- especially when u dont wanna lug that 580 around or in a tight spot-
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 06, 2008 07:11 | #5 Brainstormer wrote in post #6251948 Do they have any real use, apart from snapshots? I would rather my camera didn't even have a built-in flash. It's totally useless for me. Skip Douglas
mrklaw Senior Member 678 posts Joined Jan 2006 More info | I think I got ok fill at tokyo disneyland once. But recently it was useless as I needed a fast shutter speed on a bright day, and it doesn't support high speed sync. So its only good if you can get 1/250 outdoors for fill. _______________
Mark Dammit I need sleep 3,386 posts Joined May 2008 Location: Perth, Australia More info | Sep 06, 2008 08:04 | #7 I have used mine once, and it resulted in a much better picture than a black frame, so yes, they do have their uses! Mark
chris250 Member 198 posts Joined Oct 2007 Location: Ayrshire, Scotland More info | Sep 06, 2008 15:41 | #8 they do have their uses, i use mine as a trigger mostly as i don't have a hot shoe adapter for my stuido set up yet, you need to use slowwer shutter speed than you would normally to allow the other flashes to fire.
bohdank Cream of the Crop 14,060 posts Likes: 6 Joined Jan 2008 Location: Montreal, Canada More info | Sep 06, 2008 16:37 | #9 I use it for outdoor fill for portraits in harsh light or head and shoulder small group shots. Works well also when there is no light and you don't want to drag an external flash mounted on a camera, just-in-case. I've even gotten good flash only shots with it. Bohdan - I may be, and probably am, completely wrong.
s8langwo Member 229 posts Joined Oct 2006 Location: S.W. Michigan More info | Sep 06, 2008 18:38 | #10 I could never figure out how to fire the pop up flash without it first firing a pre-flash. The pre-flash all too often triggered my older optical slaves. I really didn't find the "digital" peanut slave triggers reliable enough to use. I did not consider this as a long term solution for firing optical slaves. 7D, 85mm 1.8, 70-200mm 4.0 (non-IS), 24- 105mm 4.0, 430 EX (2X), and assorted useful accessories. (Some not so useful too!)
| Latest registered member was a spammer, and banned as such! 2915 guests, 142 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
