Thread started 06 Sep 2008 (Saturday) 15:11
Some CC on my PP please
*Sonic*
Sep 06, 2008 15:11 |  #1
Played around a little with PS on this image, nothing major just trying to make it pop a bit
IMAGE: http://img.photobucket.com/albums/v442/Beanchimp/andrew02.jpg
I basically did a LAB curves adjustment, removed some noise, and ran an action on the eyes and teeth, and some sharpening
I dont know how to remove the bruise from the left eye though, I did have a try with the clone stamp and dodge & burn but to little avail
Thanks for looking
Steve
Canon 30D
Canon EF 50mm f/1.8 mkII
Canon EF 28-105mm f3.5-5.6 USM mkII
Canon EF-s 18-55mm f3.5-5.6 II
Canon EF 70-200mm f/2.8 L :lol:
Damo77
Sep 06, 2008 15:20 |  #2
Hi Steve,
I'd say you've gone a tiny bit too far with the eyes and teeth, but I'm on my crappy laptop atm, so my judgement isn't great.
The bruising should be simple enough - just loosely select the area with quick mask, then open hue/saturation, choose Yellows then click to sample the area, then nudge the Hue slider across a little.
Damien
Website (external link) | Facebook (external link)
*Sonic*
Sep 06, 2008 15:33 |  #3
Thanks Damien
I forgot to check the opacity of the layers on the teeth and eyes, but its easily redone, as it only took a couple of minutes to do the total editing
Thanks for the tip on the bruising, Ill give that a try
Canon 30D
PixelMagic
Sep 06, 2008 15:36 |  #4
To my eyes there seems to be an odd yellowish-green color cast that is quite noticeable in the skin tones.
*Sonic*
Sep 06, 2008 15:41 |  #5
One thing I have just remembered is that I have played around with colour profiles and the above picture is Adobe RBG not sRGB
Not sure if that makes any difference or not
Canon 30D
bohdank
Sep 06, 2008 16:17 |  #6
Yes it would since anyone using IE for their browser, like me, won't show it correctly. Change it to sRGB.
*Sonic*
Sep 06, 2008 16:18 |  #7
I have changed it back now :)
Canon 30D
*Sonic*
Sep 06, 2008 17:04 |  #8
Have done another edit, reduced the opacity of the teeth, and only slightly brightened the whites of the eyes
And switched back to sRGB
IMAGE: http://img.photobucket.com/albums/v442/Beanchimp/andrew03.jpg
Canon 30D
bohdank
Sep 06, 2008 19:12 |  #9
The eyes still seem to be overly accentuated. A little scary, actually. Just my opinion so take it for what's it worth.
I see little or no change in the green.
PhotoJourno
High Plains Chimper
Sep 06, 2008 19:15 |  #10
sonic, I'd avoid doing too much of anything with the PP, it is then that things get truly complicated.
At any rate, this last edit looks awesome. I like how the subject pops on the pic. My son just lost the same tooth, but from the top.
I think it's good. :)
--Mario
"Sensa luce non si vede nessuna cosa"--Lorenzo Ghiberti
*Sonic*
Sep 06, 2008 19:49 |  #11
No worries, im glad of the feedback, after all it will help me learn
For reference though, here is the completly un-edited image, purely resized for posting here
IMAGE: http://img.photobucket.com/albums/v442/Beanchimp/andrew05.jpg
Be interesting to see if you still see the green, or if the eyes still seem over accentuated
Steve
Canon 30D
PixelMagic
Sep 06, 2008 21:21 |  #12
Looking at the original image; the pinpoint catchlights indicate you used the onboard flash. The green color cast is being caused by the flash reflecting off the background. There are several ways to correct the color cast but the simplest would be to use a Magenta Photo Filter adjustment layer at about 15% in Photoshop (magenta is the opposite of green). Then if you still want to warm up the image you can add another Photo Filter adjustment layer; this time using the Warming filter.
*Sonic*
Sep 07, 2008 05:06 |  #13
Thanks Fedka
I did use the onboard flash as it was dark outside, I dont see the green cast, but I do see the green background, so maybe my eyes are being tricked slightly by too much greenery
Ill give the filters a go and see how it looks then
Canon 30D
1,888 views & 0 likes for this thread, 5 members have posted to it.
1141 guests, 167 members online
