Thread started 06 Sep 2008 (Saturday) 19:15
reading and watching David Hobby from Strobist.com
tomdlgns
Post edited 10 months ago by tomdlgns.
Sep 06, 2008 19:15 |  #1
editing post for removal.
none
craiglee
Sep 06, 2008 19:27 |  #2
ETTL is auto, but you can do FEC which can adjust the flash. for instance if you bounce the flash on the ceiling, you will need to FEC by +1 or so to compensate for the extra distance the light has the travel and the power lost do to diffusing.
http://www.richardtyi.​com/ (external link)
http://www.richardtyi.​com/blog (external link)
potn feedback
Curtis ­ N
Master Flasher
Sep 06, 2008 19:30 |  #3
E-TTL is the form of automatic flash metering used by Canon digital cameras. Yes, it's auto. You can adjust it up or down by up to 3 stops in 1/3 stop increments. This is known as flash exposure compensation (FEC). You can also leave the flash setting at O and set the FEC with the camera (+/- 2 stops).
In manual mode, .3 is 1/3 stop, .7 is 2/3 stop. 1/2 -.3 is the same as 1/4 +.7.
Multi flash mode is a specialized feature that allows multiple flashes during the same exposure. It's used to freeze a moving subject several times in a frame which is a cool effect if done right.
Curtis ­ N
Master Flasher
Sep 06, 2008 20:07 |  #4
Automatic flash metering in various forms has been around for 40 years and can be quite valuable.
For one thing, you can't always predict what your subject distance will be. E-TTL lets you get the shot without first having to judge the distance and adjust the flash power accordingly.
Secondly, when you're bouncing flash or using a diffuser, it can be extremely difficult to guess how much power you'll need. E-TTL lets you use those techniques without trial and error.
1,128 views & 0 likes for this thread, 3 members have posted to it.
1398 guests, 170 members online
