This should be an easy question for those who already have a dslr. With a first purchase what things do you recommend to go with the camera? grip, flash, top of line storage disk etc etc
if it helps im buying the 50D
Sep 08, 2008 03:19 | #1 This should be an easy question for those who already have a dslr. With a first purchase what things do you recommend to go with the camera? grip, flash, top of line storage disk etc etc 6D; canon 85mm 1.8, Tamron 24-70mm VC, Canon 135L Canon 70-200L is ii
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Sep 08, 2008 03:23 | #2 A good flash unit will help a lot - look into the 430EX or 580EX. Gear Listhttp://www.codastudios.com.au
seeing it is my first camera and everyone asks what are you going to shoot? Im smart enough to know that I dont know what I need. So this is how I figured it. I was first planning on getting the 17-85mm as a kit but the figured I would probably just sell it later on for a better lense anyways. So I decided agianst that. Now I am thinking of getting the 50mm 1.8 because it is so cheap and should still get me some pretty good shots. If I dont like it i havent spen any money. The only other glass that im really inerested in is the 85mm 1.8. I only want to buy lenses once (50mm being the exception) and if I bought the 85 now i will probably have i many years down the road as well. 6D; canon 85mm 1.8, Tamron 24-70mm VC, Canon 135L Canon 70-200L is ii
bohdank Cream of the Crop 14,060 posts Likes: 6 Joined Jan 2008 Location: Montreal, Canada More info | Sep 08, 2008 05:34 | #4 A grip is not necessary unless you shoot 500+ plus shots between charges (probably more... haven't shot more than 500 in one day). If you think you need more battery life, get another battery. For one thing, it's lighter and much cheaper. Bohdan - I may be, and probably am, completely wrong.
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Sep 08, 2008 06:04 | #5 elitejp wrote in post #6263422 I was first planning on getting the 17-85mm as a kit but the figured I would probably just sell it later on for a better lense anyways. So I decided agianst that. OK, so after you add the EF-S 17-55/2.8 IS to your list at about $1000, what's left in the budget?
sadx Member 143 posts Joined Aug 2006 More info | Sep 08, 2008 06:09 | #6 I suggest go for flash since 50d is quite big if without grip should be not a problem or later then you get it. Canon 50D Canon gripBG-E2N
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 08, 2008 06:29 | #7 bohdank wrote in post #6263593 A grip is not necessary unless you shoot 500+ plus shots between charges (probably more... haven't shot more than 500 in one day). If you think you need more battery life, get another battery. For one thing, it's lighter and much cheaper. For me, using a grip has nothing to do with battery "life". I only use one battery at a time in my 20D's "grip". The "grip" is purely and simply for how it allows me to hold the camera. I use mine with the Canon hand strap. Skip Douglas
kniteshade Member 45 posts Joined Oct 2007 More info | Also, the battery life is only really 'extended' with a grip if you don't have 1minute to spare when shooting to change a battery. 400D+grip / Tamron 17-50 f2.8 / 50 f1.4 / 18-55 Kit / 75-300 Kit
great info: so there is really no dramatic need for the grip. And at around 500 shots before changing batteries that is also quite duable. 6D; canon 85mm 1.8, Tamron 24-70mm VC, Canon 135L Canon 70-200L is ii
PhilV Goldmember 1,977 posts Likes: 75 Joined Jan 2005 Location: S Yorks UK More info | Sep 08, 2008 07:34 | #10 kniteshade wrote in post #6263915 You'll need to buy a second battery anyhow when you get the grip as they need 2 to run the camera You may need to send your grip in for repair, as mine and everyone else's that I know, work fine with one battery in the grip. Gear List
leadweight Senior Member 252 posts Joined Aug 2008 More info | Sep 08, 2008 07:42 | #11 The 50 1.8 is really a portrait lens. Its a bit too long to use as an all around lens. True, its a great deal, but its also something else to drag around. The 17-55 f/2.8 IS is nice if you don't mind the high price, or for $450 you could get a Tamron 17-50 f/2.8. I am very happy with mine.
the reason I kinda decided on the 50mm as my sole lense is because it is just plain cheap and I could gain experience from it. I prob. wont be able to use any L lense to the fullest anyways at this point of time. 6D; canon 85mm 1.8, Tamron 24-70mm VC, Canon 135L Canon 70-200L is ii
PhilV Goldmember 1,977 posts Likes: 75 Joined Jan 2005 Location: S Yorks UK More info | Sep 08, 2008 12:25 | #13 elitejp wrote in post #6264122 the reason I kinda decided on the 50mm as my sole lense is because it is just plain cheap and I could gain experience from it. I prob. wont be able to use any L lense to the fullest anyways at this point of time. Once christmas rolls around I will have an idea of what my next lense should be and I will have more play money. Also I can better answer the question "Do I hate primes or am I pretty satisfied." "is it too short? too long?" etc. I still believe there's some twisted logic at play here. I'm not knocking the nifty fifty, but if it was the only lens I had, I'd have very few occasions to get the camera out. It's simply not suitable for 80% plus of everyday photography. Gear List
leadweight Senior Member 252 posts Joined Aug 2008 More info | Sep 08, 2008 13:17 | #14 If you feel compelled to shoot a prime, the Canon 35mm f/2 would be a better choice, but it costs slightly more than the 18-55 kit zoom.
drewski Member 53 posts Joined Aug 2008 Location: SF Bay Area, CA More info | Sep 08, 2008 19:00 | #15 you said one of the features you were looking at was FPS. 5DMkIII | 7DMkII | M6 | EF 16-35 f4L | EF 24-105 f4L II | EF 70-300 f4-5.6
| Latest registered member is semonsters 1519 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
