editing post for removal.
tomdlgns Senior Member 541 posts Joined Sep 2007 More info Post edited 10 months ago by tomdlgns. | Sep 08, 2008 08:33 | #1 editing post for removal. none
jcolman Goldmember More info | Sep 08, 2008 08:39 | #2 That's because your 580 has high speed sync capabilities. Great feature for capturing those "sun in the shot" pics. Also, studio strobes will sync at slower shutter speeds than speedlights.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 08, 2008 09:14 | #3 Shutter is a mere moving slit rather than the full size of the sensor, when the shutter speed is fast. Therefore if the very fast (e.g. 1/1000 burst of light) flash emits all its light, it exposes the sensor only where the opening of the small slit happens to be. So normally the fastest X sync speed is the quickest shutter speed where it is the full sensor size rather than a mere slit. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
msowsun "approx 8mm" More info | Sep 08, 2008 09:28 | #4 tomdlgns wrote in post #6264209 when i am in ETTL mode with the 580ex II my camera shutter only goes to 1/250. however, when i put the flash in M mode, i can put the shutter as high as i want on my camera.
msowsun "approx 8mm" More info | Sep 08, 2008 09:54 | #5 tomdlgns wrote in post #6264623 does the flash act the same way on the camera as it does on a hot shoe cable? Yes, it will act exactly the same way if it a Canon compatible dedicated off camera shoe cord. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
msowsun "approx 8mm" More info | Sep 08, 2008 09:59 | #6 You must have the High Speed sync enabled, or your off camera shoe cord is not working properly. (or it is not a Canon compatible, dedicated off camera shoe cord) Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Sep 08, 2008 10:01 | #7 Wilt wrote in post #6264405 Shutter is a mere moving slit rather than the full size of the sensor, when the shutter speed is fast. Therefore if the very fast (e.g. 1/1000 burst of light) flash emits all its light, it exposes the sensor only where the opening of the small slit happens to be. So normally the fastest X sync speed is the quickest shutter speed where it is the full sensor size rather than a mere slit. This is correct. A bit more in depth... So, the shutter is made up of two 'curtains'. For exposures at or less that your flash sync speed the way the sensor gets exposed is this: 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
shutterfiend Goldmember 2,058 posts Joined Feb 2007 Location: NJ More info | Sep 08, 2008 10:02 | #8 Sync. speed (limit) of a camera is the fastest shutter speed at which the entire sensor (film) is exposed at some point during the exposure. https://photography-on-the.net …p=7812587&postcount=91776
Sep 08, 2008 10:05 | #9 tomdlgns wrote in post #6264648 then how am i able to adjust my shutter speed that high with the flash? In manual mode it will 'let' you put the shutter higher than the sync speed. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 08, 2008 10:05 | #10 tomdlgns wrote in post #6264623 i had my flash on and he ss was at 1/4000 and it was taking pics. they were dark, but i was taking pics. Re-read paragraph #2, message #4. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Sep 08, 2008 10:13 | #11 tomdlgns wrote in post #6264733 i am still confused about flash syncing... i based off of the posts posted, i am still failing to realize what it is. So my post ( #10 ) made no sense? What part are you having trouble with? All of it? 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Sep 08, 2008 10:19 | #12 tomdlgns wrote in post #6264761 you did a good job of explaining how it works, but i want to know what settings i need to set on my camera/flash to be able to 'flash sync' if my camera shutter is set to 250, how do i flash sync it with 1 flash? how about 2 flashes? As long as your shutter is at or slower than the max sync speed you will be fine. The camera will trigger the flash while the shutter is fully open. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
msowsun "approx 8mm" More info | Sep 08, 2008 10:20 | #13 When you put your 580EX II on the camera, or on a off camera shoe cord, it will automatically sync with the camera. There is nothing else you need to do. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Sep 08, 2008 10:21 | #14 tomdlgns wrote in post #6264761 if my camera shutter is set to 250, how do i flash sync it with 1 flash? how about 2 flashes? For two or more flashes for the most part the same applies... but it depends on the way you are triggering the flashes. Some trigger methods will require you to be set a little below max sync speed. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Sep 08, 2008 10:21 | #15 Dermit wrote in post #6264779 As long as you shutter is at or slower than the max sync speed you will be fine. The camera will trigger the flash while the shutter is fully open. If you want to use faster than the sync speed just flip the flash to HSS. But just be aware that this will yield lower power of the flash which will be fine for fill flash or closer camera to subject distances. It just won't deliver high power flashes. ok, what is the sync speed? none
| Latest registered member is Mihai Bucur 1398 guests, 170 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
