I've been able to find some info on this for other Canon cameras, but nothing specific for the G6.
If I want to use monolights (for instance Alien Bees), I need to (as I understand it) get a hotshoe to sync cord adapter. So far that's no problem. The worry I have is that the monolights will exceed the trigger voltage limits for the G6 and damage my camera.
Should I assume the G6 fits in with the other EOS cameras mentioned in these discussions and has a limit of 6v making the Bees safe or should I go for another $50 and use a Wein safe shoe or whatever it's called.
I'm assuming any of the above will work with the G6. I'm also assuming that this arrangement will eliminate any of the pre-flash triggering problems caused by using the in camera or EX external units as triggers. Please set me straight if I'm incorrect about this.
Thanks,
Jim
