Thread started 08 Sep 2008 (Monday) 19:41
Tripod Ring Repair ?
Diver-Down
Sep 08, 2008 19:41 |  #1
I over tightened the stud on my tripod last night and broke the bushing in the tripod ring. It actually broke pretty easy when I rotated the lens an 1/8 turn to snug it up. Anyway I called Canon tonight and the parts department said that only the ring is available (for about $150) and not just the bushing, which is easily replaceable i.e.: two screws on top of the "foot". Anyone ever have this problem ? or know where to get a replacement bushing ? Lens is a 100-400 IS L
silverwolf
Sep 08, 2008 20:26 |  #2
Sorry to hear that.I broke my tripod collar too i wore a notch in mine :(i have the 400 prime.Its not the same without it.Goodluck
One world one camera ton of L glass your creation your memory.
Sean's Gear 40D BG-E2N Grip l 400D XTI Canon Zoom's 10-22 l 18-55 l 28-135 Canon Prime's 50 1.8 l 400 5.6L Gitzo GT3540XLS
ed ­ rader
"I am not the final word"
Sep 08, 2008 20:41 |  #3
Diver-Down wrote in post #6268238 (external link)
if you constantly overtighten a bolt or screw the effort will seem pretty easy when it finally fails.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
fxk
Location: The vast wilderness of the Mid-Atlantic states
Sep 09, 2008 07:15 |  #4
I do not know if your tripod ring is a "a" or a "b" type - look on the little oval plate on the ring...
E-bay has sellers with aftermarket rings for far less than the $150 Canon ring. Might want to try that.
If you're handy, you could probably make a new bushing.
gasrocks
Sep 09, 2008 09:42 |  #5
If you live in a fair size city, take it to a machine shop. They might be able to fix it.
jdkeck
Sep 09, 2008 22:49 |  #6
gasrocks wrote in post #6271977 (external link)
A good auto repair shop may also be able to help.
If all you did was to strip or pull the threads out, a threaded insert could be a reasonable repair. I don't think there is enough material to install a heli-coil, but there may be enough for a nutsert. I'm not positive and don't want to do a destructive test, but I think the threads on the Canon Tripod Ring are aluminum. Good luck with the repair.
Jeff
Life is not measured by the number breaths we take but by the moments that take our breath away.
number ­ six
fully entitled to be jealous
Sep 10, 2008 15:26 |  #7
jdkeck wrote in post #6276428 (external link)
Or better yet, an automotive machine shop.
A helicoil doesn't need much extra diameter. If you're handy with tools you can install one yourself - you just drill out the hole to the specified size and re-tap the hole with the special tap that comes in the helicoil kit. Smaller size kits run about $25-35 last time I bought any.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
Diver-Down
Sep 10, 2008 18:25 as a reply to  @ number six's post |  #8
The tripod ring is aluminum then it has a steel bushing insert. The steel bushing insert broke off the cap that it is attached to. I think that the hole is already too big to put a heli coil into because I really need to stay with the same size threads so I can still use the mounting hardware for my tripod.
I suppose I could epoxy the broken part of the bushing into the hole but it fits very tight and I doubt that it would hold enough to trust. I tried calling all around Canon again today but no one could help me short of buying a new ring. Guess I'll have to come up with some sort of repair.......
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Sep 10, 2008 18:30 |  #9
personally, I'd be spending the $150 for a new ring. The cost of repairing a 100-400L and body if it hit the deck (or worse) due to a dodgy helicoil/epoxy repair would exceed that by quite a bit...
TF posting: here :-)
number ­ six
Sep 10, 2008 19:09 |  #10
Diver-Down wrote in post #6282482 (external link)
A helicoil restores the original thread size. But I'm not getting the picture here - how about a photo?
Epoxy is a risky way to repair threads. I agree with joeseph on that. OTOH, a helicoil is stronger than the original threads if they were tapped in aluminum.
As any machinist will tell you, there are a hundred ways to do anything. Perhaps an insert is required?
-js
"Be seeing you."
jdkeck
Sep 10, 2008 19:24 |  #11
If the insert is a cylindrically symmetric part, you may be able to get a replacement part machined at a reasonable cost. Take the pieces to a machine shop and get their opinion.
Jeff
jdkeck
Sep 10, 2008 19:35 |  #12
From the measurements I could make without taking the insert out of the foot, it looks like a 1/4-20 Thread-Sert (the Marson Brand) could be installed. The drill size for the insert is 25/64" (0.390") and the hole is less than 0.34".
Jeff
Diver-Down
Sep 10, 2008 21:05 as a reply to  @ jdkeck's post |  #13
Thanks for measuring that Jeff, I guess I'll give the helicoil a shot but if it doesn't work out 100% I'm not going to use it and risk the lens falling off. I'll probably keep an eye out on e-bay as well, I would just rather not hang a piece of L glass off one of those cheap o rings.
jdkeck
Sep 10, 2008 21:54 |  #14
A thread-sert is not a heli-coil. I don't have the specs for heli-coil inserts. This is a thread-sert, http://www.huck.com/ma​rsoncorp/threadsert.ht​m (external link) . They come in both aluminum and steel. A special tool is needed to compress the insert that may not be worth a one time use. A machine shop, either regular or auto, should have the tools. On the other hand, they are very handy for repairs. In addition to the thread-sert style, there is a rivet style that is designed for use in thin materials.
Jeff
1,937 views & 0 likes for this thread, 8 members have posted to it.
1332 guests, 137 members online
