Thread started 09 Sep 2008 (Tuesday) 10:46
How to make a precise line when adding color to eyes, lips?
PhotoGuru13
Sep 09, 2008 10:46 |  #1
I have been playing with my new software , PS Elements 6.0. I tried a few different brushes to get a feel for coloring in eyes, and lips on this B&W pic. I zommed in, but do I need a real steady hand to outline the lips, or is there a different method (paint bucket) that will fill the lips in with color, more pricisely and accurately? Thanks in advance!
Bobster
Sep 09, 2008 12:13 |  #2
lasso tool is your friend, zoom in, and using the polygon lasso click points around the area you want to select, then feather by a couple of pixels (helps smooth out the lasso selection) and make your corrections/alteration​s
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
DavidSR
Sep 09, 2008 14:47 |  #3
I used to use the lasso tool, but that thing is a pain..it won't let me go back and readjust. Now, I use the pen tool I can delete whichever points were put there by mistake and re-do them :). I always feather around 2-3 pixels.
T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
René ­ Damkot
Sep 09, 2008 15:21 |  #4
If PSE6 has a pen tool, I recommend that.
(Since it's easiest to go back to and adjust)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PhotoGuru13
Sep 09, 2008 15:40 |  #5
René Damkot wrote in post #6274105 (external link)
It has a pencil too (which I used) is that close enough?
PixelMagic
Sep 09, 2008 15:59 |  #6
Are you painting with a mouse?
Peano
Sep 09, 2008 16:07 |  #7
PhotoGuru13 wrote in post #6274244 (external link)
No, they're not the same. Forget the pen tool. It's a terrific tool, but it's also an advanced tool (and Elements doesn't have the pen tool anyway). Get the basics down first.
I assume you're using a mouse. One way to precisely select eyes, lips, etc., is with quick mask. To paint more accurate edges, use the "shift-click" method. Practice this on a blank document just to get the feel of it:
  • With the paintbrush, click once to make a spot.
  • Move the cursor to a nearby position.
  • Hold the shift key and click again.
  • Move the cursor again.
  • Hold shift and click again.
This method allows you to position the cursor precisely before you shift-click to connect the dots. With very little practice, you can use this method to paint accurately around the inside edges of lips and such. (You should, of course, zoom in close enough to see small details.)
HTTP response: NOT FOUND | MIME changed to 'image/jpeg'
Peano
RadiantPics.com (external link)
D ­ Thompson
Sep 09, 2008 16:36 |  #8
DavidSR wrote in post #6273891 (external link)
Sure you can readjust after the initial selection. On a PC just hold the {shift} key to add to the selection or the {alt} to subtract from the selection. Mac it's the {shift} and {option} keys.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
DavidSR
Sep 09, 2008 16:53 |  #9
D Thompson wrote in post #6274538 (external link)
I know what you mean, but what I was referring to was the ability to go back to specific points in 1 selection and I guess I'm trying to say re-plot the points if that makes sense. What you are saying is to select the whole eye and than hit the shift key and select the other eye to have them both selected.
Bobster
Sep 09, 2008 17:06 |  #10
theres a tool called the zoom tool, it allows you to magnify the image so you can get a better selection, if you grab the zoom tool, click at one side of the eye and drag to the other, it will zoom the eye to fit the open window area
PhotoGuru13
Sep 09, 2008 20:08 |  #11
FedkaTheConvict wrote in post #6274341 (external link)
YES..is there a different option?
Bobster
Sep 09, 2008 20:38 |  #12
yes (external link) much easier as well :)
opus13
Sep 09, 2008 21:52 |  #13
i always use the pen tool to create selections. it will provide a cleaner line and and provide smoother curves (as compared to the wand/etc)). make you line, then ctrl+click the layer icon. the selection will automatically be antialiased, and you can go on your way. if you use the shapoe as a color overlay or mask, it is entirely non-destructive. no ctrl-z through your history hoping to get back to a previous state.
mah stuff (external link)
bieber
Sep 09, 2008 22:29 |  #14
Look up quick-mask mode?
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
D ­ Thompson
Sep 09, 2008 23:20 |  #15
DavidSR wrote in post #6274629 (external link)
Exactly. You've made you're initial selection and you want to modify it because you either didn't get part of what you wanted or got a part you didn't want. You can add or subtract from your initial selection by holding the shift or alt and drawing with the lasso the parts you either want or don't want. Holding one of those keys and redrawing parts of the initial selection will modify your selection so that you can fine tune it to exactly what you want. Hope I'm making this a little clearer.
You can use it like that also.
Dennis
2,289 views & 0 likes for this thread, 12 members have posted to it.
979 guests, 180 members online
