Thread started 09 Sep 2008 (Tuesday) 11:17
Neutral Density Filter
Docthomas
Sep 09, 2008 11:17 |  #1
I am looking for a decent ND not a GND and I know when I was looking for a CPL everyone made a huge deal about getting the correct Hoya or B&W
I don't see the same fervor over the NDs. So for a twist-on ND what are people using and what should I go for or avoid?
HVstar has several as do BH and Adorama. any suggestions greatly appreciated.
Thank you
Shawn.
80D, 28-135 IS F3.5-5.6, 70-300 IS USM f4-5.6, Tamron 17-50 2.8, nifty-fifty, sigma 10-20,
krb
Sep 09, 2008 11:19 |  #2
The same quality issues that apply to a CPL apply to *all* filters. You mostly see it about UV and CPL because those are far more commonly used than other filters.
-- Ken
Gear list
Docthomas
Sep 09, 2008 11:20 |  #3
Ok, point taken but even within hoya and B&W there are choices.
any problem with stacking two CPLs for a simialr effect?
krb
Sep 09, 2008 11:40 |  #4
You can stack CPLs but you'll want to be careful about alignment. And you should always try to minimize the number of layers you are adding so a single dark ND is better than 2 CPLS or 2 lighter NDs. Adding a second filter means doubling the chances of dust, scratches or flaws in the glass.
-- Ken
Gear list
luigis
Sep 09, 2008 11:46 |  #5
One of the best NDs is the Singh-Ray vari-ND you can adjust the darkness by twisting the filter so you have flexibility.
Hoyas NDs are very good ones too
Stacking CPLs is not the same because you are getting polarized light thru the CPLs while the NDs just darken the scene without polarizing effect, sometimes you want to polarize and sometimes you don't.
Luigi
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
RPCrowe
Joined Nov 2005
Sep 09, 2008 11:57 as a reply to  @ luigis's post |  #6
Variable Neutral Density Filter
Check out this link:
http://digital-photography-school.com …e-neutral-density-filter/ (external link)
Docthomas
Sep 09, 2008 12:29 |  #7
I saw that saw article. very interesting. here's what i was considering. I have a nice CPL and was considering adding a 4x and possibly an 8x.
http://hvstar.net …ction=VIEWPROD&​ProdID=195 (external link)
get the 72 and the convertor rings for my 58 and 62s?
but then at BH they have 3 price classes one at $40-ish and one near $100 and one over $125??
doing a mfr# check the HVstar ND is equal to this one at B&H
http://www.bhphotovide​o.com/c/produc...l_Den​sity.html (external link)
so what is the difference? coatings again?
luigis wrote in post #6272736 (external link)
Luigi
at quite a premium too. lots of warnings even on the Singh_ray site about fringing and color abberations though. anyone use this?
comes in a 77 so I'd have to have conversion rings too.
Docthomas
Sep 09, 2008 13:14 |  #8
I read about buying one filter and putting converters on to allow it to fit on all lenses.
Singh-Ray is only making 77 and 88mm versions now so if I did this a 77 vari-ND on my 72mm would be fine but down to my 58? that's 19mm. Seems like too big a leap. chances of me wanting to use it on this lens is small but still just a question. is there a limit on how big a difference there should be between filter and lens in this situation?
jdizzle
Darth Noink
Sep 09, 2008 21:53 |  #9
I also like the B+W 10 stop ND but, I wish they made it in 82mm. I also want the Singh-ray Vari-ND but, I hope that this is the last type of filter I have to buy.
Link: http://www.bhphotovide​o.com …29_77_mm_110_Ne​utral.html (external link)
Hermes
Sep 09, 2008 22:02 |  #10
Luigi
The Singh Ray IS a stacked CPL and linear polariser. You can't combine it with a another CPL to get polarizing effects and it isn't multi-coated so you are adding two potentially flare-inducing elements to your optical chain by using it. Add to that the fact that you'll probably have to use step-up rings to attach it and therefore lose the ability to use your lens hood, and it seems like a waste of money when you could get a properly sized and multicoated, single-element ND filter for much less.
1,364 views & 0 likes for this thread, 6 members have posted to it.
669 guests, 121 members online
