Thread started 09 Sep 2008 (Tuesday) 15:16
Sporadic Misfire with Strobes
bmatanane
Sep 09, 2008 15:16 |  #1
I have a 3 light studio setup using Photoflex monolights and I shoot with a 1D Mark III. After several shots I get an occasional misfire from the the main light which is connected to my camera via a sync cord. I have to fire off a test flash to get the main to fire again or turn off/on the camera which sometimes works. How can I isolate the source (camera or strobe) of the misfires? Or is the camera on a wrong setting? Help!
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Sep 09, 2008 16:47 |  #2
The prime suspect is the PC-Synch cable. Try another one, preferably with a screw-in fitting at the camera end.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
bmatanane
Sep 10, 2008 00:39 |  #3
Couldn't locate a screw-in fitting pc-sync cable but a fresh one seems to be doing the trick. I had no idea these cords can be so tempermental. It may be time soon to go with Pocket Wizards. Thank you for the suggestion!
tim
Light Bringer
Sep 10, 2008 01:47 |  #4
Skyports (external link) are a cheaper but still reliable alternative to PWs. Locking cords should be available from www.flashzebra.com (external link) and custom made for you if you want a different length. Or just use a speedlite set to manual and 1/64th to trigger the lights.
Jannie
Sep 10, 2008 17:32 |  #5
If I use Elinchrom 400BX monolights will the Speedlight set to 1/64 trigger them?
Ms.Jannie
"When you come to a fork in the road, take it"!
1DMKIII, 85LII, 24-70L, 100-400L
tim
Light Bringer
Sep 10, 2008 17:38 |  #6
It will trigger any studio slave with an optical sensor, which is all of them I think. I point it at the ceiling, or towards one of the strobes. Sometimes 1/128th works, sometimes it's 1/16th. Either way it should make no difference to the exposure.
Jannie
Sep 10, 2008 19:20 |  #7
Thanks.
Ms.Jannie
1,597 views & 0 likes for this thread, 4 members have posted to it.
2873 guests, 131 members online
