Thread started 09 Sep 2008 (Tuesday) 15:36
quick question, just need a little help..
Ryan.
Sep 09, 2008 15:36 |  #1
I was wondering what I need to use a 430ex off camera? I wanted to place the 430ex somewhere else and try shooting from different angles. What would you guys suggest I do?
-Ryan.
Ryan.
Sep 09, 2008 15:40 |  #2
Actually I think I just found it..
Would this do the trick?
http://cgi.ebay.com …1318&_trksid=p3​286.c0.m14 (external link)
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Sep 09, 2008 16:42 |  #3
Yes, that would work. The manufacturing quality is not good, and many people have run into problems, but many have not.
An alternative source (Cactus brand) is:
www.gadgetinfinity.com (external link)
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
Ryan.
Sep 09, 2008 16:51 |  #4
Thank you, I'll look into those.
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 09, 2008 17:29 |  #5
If you go with a wireless radio trigger, you can't use ETTL because the flash will not be able to communicate with the camera. You will have to use manual control on the flash and adjust power as needed for each exposure. (1/8, 1/4, 1/2, etc.)
Ryan.
Sep 09, 2008 17:49 |  #6
msowsun wrote in post #6274797 (external link)
oh ok, thats fine with me. Which triggers out there would the ETTL work with?
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 09, 2008 19:07 |  #7
Ryan. wrote in post #6274892 (external link)
NONE....
Only the Canon wireless system found in it's Master/Slave flashes will give you ETTL. There is a brand called "Radio Popper", but they just relay the Canon signal between the Master and the Slave.
Here is some reading on the Canon wireless system: http://photonotes.org …lash/index3.htm​l#wireless (external link)
Ryan.
Sep 09, 2008 19:56 |  #8
msowsun wrote in post #6275281 (external link)
NONE....
ok, thanks.
1,322 views & 0 likes for this thread, 3 members have posted to it.
1411 guests, 176 members online
