Thread started 09 Sep 2008 (Tuesday) 21:21
Shooting with speedlight flash - technique
USER876
Sep 09, 2008 21:21 |  #1
I was taking pictures at a friends wedding the other weekend, and I noticed in a few of my pictures I actually have their wedding photographer in the frame. I noticed how they were shooting indoors at the reception, take a look....
I was using my 430EX and the room was very large, with high ceilings, and dark walls, the bouncing was not working so I aimed the flash about 45 degrees upward. The wedding photographer shot like this all night (see first 2 pics below), with the flash positioned 180 degrees behind, is this what I should of done?
HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO
The second wedding photographer used a paper card and aimed forward......
They both must of had super fast lenses, I remember trying to autofocus a frame and they would pop in focus, shoot, and walk away while I was still framing and focusing.
Anyway, So whats the best technique? My pictures came out pretty good, about 50% usable, and I aimed the flash anywhere from directly at the subject to 30-45% upward.
mattograph
"God bless the new meds"
Sep 09, 2008 21:23 |  #2
Were they using off camera flash? It looks like they were using the on camera flash to trigger some slaves.
This space for rent.
USER876
Sep 09, 2008 21:45 as a reply to  @ mattograph's post |  #3
No slaves....
DDCSD
GIVIN' GOOD KARMA
Sep 09, 2008 21:48 |  #4
Bouncing behind you works great in the right situation. I usually do that if I can get away with it. I wouldn't have had that stofen thing on my flash when bounding though. The bounce card (last image) is a good idea in many cases though.
Have a look at this website. It does a better job explaining it than I ever could.
http://planetneil.com …h-photography-techniques/ (external link)
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
mattograph
Sep 09, 2008 22:00 |  #5
Heres one for you....
She turned it to bounce in a specific situation, and forgot afterwards.
I have seen that happen.
In face, I may have done it once or twice! :)
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Sep 09, 2008 22:05 |  #6
She's using a 24-70 f/2.8L there... the AF assist beams on the 580 will make focusing a lot easier in dark lighting, mind you!
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
DDCSD
GIVIN' GOOD KARMA
Sep 09, 2008 22:59 |  #7
mattograph wrote in post #6276161 (external link)
You must be a really sucky photog. I would never forget to turn my flash head in the right direction. And my wife has never made fun of me after freaking blinding myself with said flash head pointing straight into my eyes after forgetting to turn it when bouncing behind me.
Derek
Stealthy ­ Ninja
Location: Mythical Tasmania (the one with lots of tall buildings in the semi-tropics, A.K.A. Hong Kong)
Sep 09, 2008 23:04 |  #8
DDCSD wrote in post #6276489 (external link)
Heh, did the same thing the other day. Thank goodness for my Chinese Omnibounce.
:lol:
I often shoot backwards like that. It makes the light bounce all over the room and then back to the subject, taking away (most) flash shadows. Works well in certain situations. For example, I was practising with my flash photographing my son. We were in a lift (elevator). The lift had metal (not shiny) walls. So I bounced behind me, causing the light to scatter around the lift. Worked really well.
davo_robbo
Sep 10, 2008 06:07 |  #9
i shoot with my flash like that about 80% of the time,
gives awesome fill when your shooting in M @ -2/3 on ETTL
the light comes out so natural and soft
heres two examples
IMAGE: http://farm4.static.flickr.com/3225/2716758572_ede6826b7e_b.jpg
IMAGE: http://farm4.static.flickr.com/3086/2716763230_f648dfe097_b.jpg
5Dc | 24LII/45 TS/50L/85 Sigma
Canberra Wedding Photographer - David Robertson (external link) | [URL="http://www.faceb​ook.com/#!/pages/David​-Robertson-Photography/2927518399​29?ref=ts"]Facebook Page | [URL="http://twitter.c​om/davidrphoto"]Twitte​r | [URL="http://www.forms​pring.me/drobertsonpho​to"]GOT Photography Q's? (Formspring)
Deckham
Sep 10, 2008 06:22 as a reply to  @ davo_robbo's post |  #10
I use it that way sometimes. Depends, of course. On so many things, it just isn't worth getting into it :)
Did you happen to notice whether she had any kind of hand-held card/reflector?
Regarding this - how many milliseconds was she quicker then you?
Lulu Clake (external link)
Zenfolio  (external link)
mattograph
Sep 10, 2008 07:36 |  #11
I have never blinded myself -- my head is too short.
You must have a large mellon!;):)
suyenfung
Sep 10, 2008 07:48 |  #12
i bounce behind all the time. its a totally legit technique. if head straight forward is 0 degrees, and straight back is 180 degrees, most often i bounce at 135 degrees, back/left or back/right. this will give you modeling in the subject, broad/short light depending on the situation. looks like off camera flash if done correctly.
shoot at 1600 and a large aperture and you typically will get plenty of light.
cleveland ohio wedding photographer (external link) | gear
USER876
Sep 10, 2008 08:12 as a reply to  @ suyenfung's post |  #13
eek! I would be afraid to shoot at 1600 with a flash. Thanks for the responses, are you sure she is shooting with a 24-70 F2.8? I don't think my 430EX has enough throw to shoot with it turned at 180, maybe it's time to upgrade!
davo_robbo
Sep 10, 2008 08:18 |  #14
i usually meter to -2/3 stop (generally iso 800-1600) and shoot at f2 on one of my primes with the 580ex just giving a little fill, bouncing it to the side gives more dimension to the fill light instead of a flat fill
430ex is more than powerful enough, you only use a little bit of the flashes power and use lots of iso and large apertures to get lots of ambient light in the shot
mattograph
Sep 10, 2008 08:28 |  #15
davo_robbo wrote in post #6278581 (external link)
Dave, your shots look awesome, btw.
Are you using auto white balance for these shots? I ask, since when I have tried this under fluorescents, I have picked up colors from the walls, plus with the green light -- wb nightmare!
10,040 views & 0 likes for this thread, 19 members have posted to it.
2873 guests, 131 members online
