Thread started 10 Sep 2008 (Wednesday) 10:47
just got my cybersyncs in!!!
tomdlgns
Post edited 10 months ago by tomdlgns.
Sep 10, 2008 10:47 |  #1
editing post for removal.
none
Moonjo
Sep 10, 2008 11:21 as a reply to  @ post 6279480 |  #2
IIRC the on/test green led will stop flashing after an hour if you haven't pressed the button or the receiver has not received a transmission for the transmitter. It's designed to do that. If you do push the button or it receives a signal will will flash for another hour. There is no off switch on the receivers or the transmitter, btw.
As for the 580EX II going into standby, you'll need to change the standby period on the flash itself since, as you have already discovered, the receiver will not bring the flash out of standby mode.
EOS R5 BG-R10 | EOS R5 | Canon RF70-200 f/2.8L IS | Canon RF24-70mm f/2.8LIS | Canon EF100mm f/2.8LIS | Canon EF135mm f/2.0L | Canon EF85mm f/1.2L II | Canon EF24-105 f/4.0L IS | 580EX II.... and other lighting stuff
Facebook (external link)
Titus213
Sep 10, 2008 12:35 |  #3
Congrats, I think you'll like them. What mode is the 580EX II in? In ETTL mode I think the flash seldom fires a full or near full shot. A full manual shot with the flash does produce a noticeably different pop. At least my units do.
Dave
Perspiring photographer.
mrcpix
Gallery: 10 photos
Sep 14, 2008 09:33 |  #4
how reliable are the cybersyncs? I am going to order a set tomorrow as I need them for next weekend.
Mike Carnes
Canon 7Dmk2 gripped
Titus213
Sep 14, 2008 09:41 |  #5
I've not had one misfire on me.
Dave
evorgsumaf
Sep 14, 2008 13:06 |  #6
Very reliable. I have had mine for a few weeks now, and not a single misfire. And for the RX'er not turning off, I had the same issue except I was draining batteries in between uses, so now I store the RX'er with no batteries in it. When I need the Cyber Syncs, I pop the batteries in it and off I go.
Brandon
Titus213
Sep 14, 2008 14:51 |  #7
I was actually considering gluing a small rubber washer over the switch to prevent it from being hit in the bag...
Dave
evorgsumaf
Sep 14, 2008 14:55 |  #8
Titus213 wrote in post #6305669 (external link)
Another good idea. I will consider this once I get tired of pulling the batteries out.
Brandon
Jim ­ M
Sep 14, 2008 19:17 |  #9
tomdlgns wrote in post #6280205 (external link)
i noticed it in ETTL and manual mode.
however, in ETTL it is a little louder.
as long as this is normal, i am ok with it.
and for the record, the green led does stop flashing after a certain amount of time. i could be 1 hr, i am not sure since i wasn't monitoring it.
I'm not sure you should be able to tell the difference in ETTL since you can't use ETTL with a Cybersync. If it's going off, it is probably dumping the whole load as if it were in manual. I could be wrong. I don't use an ETTL flash when I go off camera with a radio remote.
Phil ­ H
Sep 14, 2008 20:13 |  #10
Titus213 wrote in post #6304418 (external link)
Same here - not one misfire.
I've been shooting at 160th because the owners manual said to set the shutter speed at one or two clicks below the max sync speed. (I have a 30D and 430EX's). Has anyone played around with shooting at max sync speed?
EOS 7D l EF-S 10-22 l EF-S 15-85 l EF-S 17-55 l EF-S 60 Macro l EF 70-200 f/2.8L IS l EF 85 f/1.8 l 430EX x2
grewbek
Sep 14, 2008 21:55 |  #11
The lack of an on/off switch is kind of a pain. I bought a pelican case, filled it with custom cut foam, and keep my receivers/trigger in this when in my bag. It looks like this:
I've had my cybersyncs for a couple of months now and have used them probably 20+ times. No misfires, and I love them. I have a 40D and it says max sync speed of 250, but mine will actually sync at 320. Go figure :lol:
You've probably already figured out you can change the Custom Function 1, and by changing it from 0 to 1 you turn off the automatic standby mode on Canon flashes. Hope that helps.
Pentaxis
Sep 15, 2008 12:18 |  #12
What case is that? That works pretty nicely
Titus213
Sep 15, 2008 12:36 |  #13
Looks like a 1020, 1050, something in that range.
http://www.all-pelican-cases-4-less.com …Nm89raq3pUCFQv7​agodMX9AXw (external link)
Dave
3,357 views & 0 likes for this thread, 9 members have posted to it.
1398 guests, 170 members online
