I'm curious to see how others make decisions about which of the above flash techniques to use and under what conditions. I understand the basics of each technique but would like to see what light others can shed on the subject. (No pun intended!!!)
North Hatchling 1 post Joined Feb 2005 Location: Minnesota More info | Feb 04, 2005 04:12 | #1 I'm curious to see how others make decisions about which of the above flash techniques to use and under what conditions. I understand the basics of each technique but would like to see what light others can shed on the subject. (No pun intended!!!) Canon 20D with 18-55, 10-22, 28-105, 100-300, 580EX
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Feb 04, 2005 04:28 | #2 I'm far from an expert, and everything i've learned is by trial and error. I use bounce for people if there's a low white roof, otherwise I use a diffiuser - an omnibounce. I also use the omnibounce if the flash is making the light to harsh, like when I was taking water drop photos. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
dpp Member 129 posts Joined Oct 2004 More info | Doesn't the omnibounce act the same as the Catch Light? I thought the Omnibounce not only diffused but if the flash is in bounce position it would refract the light as well.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Feb 04, 2005 16:42 | #4 The omnibounce softens light and basically makes it like it's one larger, softer light. The catchlight, as I understand it, is when the flash is pointed up and the little panel's pulled out. That means it's bounce flash with a bit of direct flash too. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is AlainPre 1767 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
