Thread started 04 Feb 2005 (Friday) 12:58
Loose Lens Tube
boz
Feb 04, 2005 12:58 |  #1
Hi All, Just bought a G6 and noticed that the lens tube that hold the lens can be moved slighly from side to side. It seems to be loose. Is this normal? I'm not talking about the lens ring but the actual tube that extends with the lens. Pictures are in focus but suspect something is wrong. Please put my mind at rest as I can't get hold of the dealer right now and want to use the camera this weekend. Thanks.
KC ­ Jewel
Joined Jan 2005
Feb 04, 2005 13:31 |  #2
I just took a look at mine for you and it also has a tiny bit of play side to side, takes wonderful pictures. Go have fun!
John
G6, 420EX, Converter W/filters, 2X Xtend-a-view, 45mm red dot speed sight with Photosolve Xtend-a-sight mount.
boz
Feb 04, 2005 15:48 as a reply to  @ KC Jewel's post |  #3
Thanks John. Mine has more than a tiny bit of play, it will actuall rattle if I shake the camera. The lens ring also is not a tight fit. Is yours?
Superbaldguy
Joined Sep 2004
Feb 04, 2005 16:06 as a reply to  @ boz's post |  #4
Ditto for me, also.
I used to worry about such annoying things (like the front lens element wobble) but life is too short for that........I'm still amazed at the image quality from this silver gem, even after almost 6000 files..........
Nabil-A
Joined Dec 2004
Feb 04, 2005 16:26 as a reply to  @ Superbaldguy's post |  #5
Just get a lensmate adapter and uv filter if such things continually bother you. As the old saying goes, what you dont see wont hurt you.
http://www.photography​bynabil.com (external link)
http://www.designerpor​traits.com.au (external link)
http://www.lovestories​photography.com.au (external link)
KC ­ Jewel
Joined Jan 2005
Feb 04, 2005 20:34 |  #6
Hi Boz
If I shake it you can hear the lens tube moving but I think they are made that way. Don't know about the ring as I use the Canon 58mm adapter so I can have filters on to protect the lens and create better color. John
bauerman
discount on value meals
Joined Apr 2003
Feb 05, 2005 09:10 |  #7
From what I have read - there should be a little bit of play in the lens assembly on the G-series cameras. Noting to worry about whatsoever. I've had a G2. G3 and G5 and they all have had it.
boz
Feb 05, 2005 11:38 |  #8
Thanks for all your replies, it's put my mind at rest. I can go out now and enjoy the camera.:D
Alnath
Joined Dec 2003
Feb 05, 2005 15:07 as a reply to  @ boz's post |  #9
Lateral movement is not a problem, its can it go in and out you should worry about.
Mine wobbles a bit as well BTW
John
Click to view my photos (external link)
2,811 views & 0 likes for this thread, 6 members have posted to it.
Loose Lens Tube
1570 guests, 131 members online
