Thread started 11 Sep 2008 (Thursday) 14:01
Question About 2nd Curtain Flash
DavidSR
Sep 11, 2008 14:01 |  #1
Hey guys,
I know what a 2nd curtain flash does and know that it is also used to capture some ambient light, but I had a question on a certain situation.
I took a picture of someone on a bridge with a nice fountain and a few lights in the background. I exposed for the person, therefore losing the fountain and lights. Would a 2nd curtain flash help me expose him correctly and get the fountain off in the distance? This was at night and I have to use at least ISO 1600 to get any of the lights to show. Wouldn't that have overexposed the subject? Sorry, but I don't have a picture to share.
Thanks for any help you can give!
T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 11, 2008 15:46 |  #2
Second curtain flash doesn't help capture ambient light.
What it does is orientate any movement captured by ambient light caused by a slow shutter speed.
A prime example is a moving train's headlights captured in a flash photo. With 1st curtain flash the lights would show an opposite movement to the car's direction because the flash occurs at the beginning of the exposure. . 2nd curtain flash would show the lights in the correct forward movement.
IMAGE: http://www.shortcourses.com/images/b4ch6/curtainsync.jpg
DavidSR
Sep 11, 2008 16:19 |  #3
Thanks for the comment! I thought I read somewhere that it helped capture ambient light..guess not..is a double exposure the only way to capture a properly exposed background and foreground?
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 11, 2008 16:21 |  #4
DavidSR wrote in post #6288401 (external link)
If you are talking about a flash exposure, no.
A long exposure on a tripod will capture as much ambient light as you want.
Wilt
Sep 11, 2008 16:41 |  #5
There is no 'double' exposure (analogous to two separate shots on the same piece of film) There are two components of the single exposure...the part created by the flash output, and the part created by the ambient light. To balance it, you control shutter speed. A short shutter speed could make everything come from the flash exposure. A slow shutter speed makes parts come from the flash and also the ambient light.
2nd curtain sync merely determines the ambient portion's position in time, versus the flash, but not how prominent.
DavidSR
Sep 11, 2008 16:51 |  #6
What I meant was to do 2 single exposures and merge them together in post processing. Basically one shot exposed for the background and the 2nd shot exposed for the subject. Seems like that's the only way to have a properly exposed background and foreground.
Thanks for the help and info.!
craiglee
Sep 11, 2008 16:51 as a reply to  @ Wilt's post |  #7
you can do h-sync flash...as long as your subject is moving really fast.
http://www.richardtyi.​com/ (external link)
http://www.richardtyi.​com/blog (external link)
potn feedback
DDCSD
GIVIN' GOOD KARMA
Sep 11, 2008 16:57 |  #8
DavidSR wrote in post #6288573 (external link)
There are many methods of doing this. One is using flash (does not matter if you use 2nd curtain sync or not). Another is blending different exposures, another is HDR tone-mapping or you could use GND filters.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
krb
Sep 11, 2008 17:03 |  #9
Absolutely that can be done, but there are others ways that may be easier.
But take a look at sapearl's post with the wedding picture in https://photography-on-the.net/forum/showthre​ad.php?t=561660 He estimates that it was a 20 second exposure to capture the background, with a flash used to clearly illuminate the bride and groom. This technique is called "dragging the shutter". It allows a long exposure for the background, either to capture ambient light or to capture motion, with a flash to "freeze" the motion of the subject.
-- Ken
Gear list
DavidSR
Sep 12, 2008 08:15 |  #10
krb wrote in post #6288643 (external link)
That was the same technique I was thinking of, I just thought that the slow shutter and flash to freeze the subject would blow out the subject because of the slow shutter. I'll have to give this a try next time I go there.
Thanks for all the help guys!
Wilt
Sep 12, 2008 09:08 |  #11
DavidSR wrote in post #6292368 (external link)
You blow out the subject only when the [Flash exposure] + [Ambient exposure] = Overexposure
If the ambient level shutter+aperture exposure is -1EV, the subject would NOT be overexposed
DavidSR
Sep 12, 2008 09:15 |  #12
Thanks! I'll have to give this a try sometime soon.
2,216 views & 0 likes for this thread, 6 members have posted to it.
2870 guests, 131 members online
