I have the folling setup
1. pocket wizard pair.
2. one canon 580ex blitz
3. one canon 580ex11 blit
When I set the 580ex11 to the camera as master and use the other ex as slave all works well.
When I connect the pocket wizard to the camera flash shoe and second pocket wizard to the sync port on the ex11 then it works and the slave flashes early.
Both flashes are on the plastic foot provided with the flashes. I read that the pre flash is fixed if I set cf 5 to 1 sett the flash as ttl.
Now when I do this the slave flash does not fire. ?
Can someone tell me how to set both flashes to manaul where second flash is slave to the first and fires together with the master. Over the camera signal
I can only get this at the moment with ettl but not with pocket wizard. Sorry if I have not explained my self well.
I had it working once for three days Shot these test shots
http://www.pbase.com/cwakefield/equipment![]()
but since the I an lost. Any tips welcome Regards Carl
