I took some shots last night using my new AB as key light and a 580 EXII as a hair light. I expected the hair light would be a tad cooler than the key light; however, it turned out to be much cooler than I anticipate.
Todays task is to determine what gel to use on my flash to most closely match the color temp of my strobe. My plan is to shoot a Grey card w/ my AB, set my camera to custom WB, take a few shots of the Grey card using various strengths of CTO, import all the files into lightroom, and then use the eyedropper to set the WB in Lightroom. The gel I used in the photo which the color temp changed the least during Lightroom adjustment will be the gel I use on my flash when I'm using it together with my strobes.
My question is this, "does anybody know of a better way to choose the correct gel"?
