Thread started 12 Sep 2008 (Friday) 14:55
Monopod for 40d
bstamper
Sep 12, 2008 14:55 |  #1
I have read and read about monopods but still can't make up my mind on what to get. (It gets cluttered when you start looking at all the options) I have a 40d and will mostly be shooting with 100-400 and 70-200, but would like it to handle the 500 or 600 if I am renting them. Not wanting to spend 1000, but definitely not expecting to spend 100. Whatever it takes to get "THE" monopod I need to handle my situation. I do think the carbon fiber is important based on most people say it is lighter. My second concern is I do travel quite a bit and would like to be able to take with me on planes with my carry on. So if it can get "small" it would be a major benefit. I am also 6'5" so it needs to be tall enough for me.
Suggestions??
Bart
gymell
Sep 12, 2008 15:31 |  #2
I have the Gitzo GM5540 which is rated to 55 lbs and easily supports the 500mm (and should certainly also support a 600mm.) I've used it with the lens mounted directly on the monopod with a RRS clamp, and recently got the RRS high capacity monopod head. I'm not sure if it would be tall enough for you though, as it only extends up to 63.8". I see that the GM3551 goes to 75.6" and supports 36.9 lbs, which I'd think should still be plenty of support for those lenses.
-Liz
My online gallery (external link) and Live Streaming Feeder Cam (external link)
Help native birds - discourage house sparrows! (external link)
Minnesota Master Naturalist (external link) - "Explore, Teach, Conserve"
bstamper
Sep 12, 2008 17:05 |  #3
I have searched for RRS clamp but can't find anything? What is it?
Any other suggestions as heads that might work well with GM3551?
Bart
darkdragon
Sep 12, 2008 17:10 as a reply to  @ bstamper's post |  #4
How about the Manfrotto 560B? I have one and love it. I am also shooting 40D and use it with my Panasonic DVX100B video camera also.
http://www.amazon.com …RJCQXJ&colid=WP​HJQPJQCGEE (external link)
~ Lisa
:D [http://www.darkdragon.​us (external link)] web
:wink: [http://darkdragon.smug​mug.com (external link)] photos
gear: Canon 10D, 40D, 580EXII, 70-200 F/2.8L, 17-40 f/4L, 50 F/1.4, 28-135 F/4-5.6 IS
bstamper
Sep 12, 2008 17:32 |  #5
Darkdragon, It is a little short for me.
I think the GM3551 would work, but need a good head to go on it.
Bart
gymell
Sep 12, 2008 20:16 |  #6
bstamper wrote in post #6295409 (external link)
Bart
Really Right stuff, here's the high capacity monopod head:
http://reallyrightstuf​f.com/tripods/04.html (external link)
And the B2-Pro/L clamp:
http://reallyrightstuf​f.com …c.asp?ic=B2-Pro/L&eq=&Tp= (external link)
You can use the clamp by itself directly on the monopod, which is what I did for a while. The high capacity head adds the ability to swivel up and down on the monopod. They also have another monopod head and different clamps, but I mention these because you were talking about the possibility of using 500mm and 600mm lenses.
-Liz
SYS
Gallery: 602 photos
Joined Jul 2004
Sep 12, 2008 21:28 |  #7
For your height and demands, I think you'll like the GM3551. I have the GM3550 which is essentially the same thing. The stuff from the reallyrightstuff above look very interesting. I use a much cheaper 3229 Tilt Head QR...
-Goethe
gymell
Sep 13, 2008 08:01 |  #8
RRS recommends the 3229 with a RRS quick release plate for a low-capacity monopod solution. However it's only rated to 5.6lb. So if you're talking about using a super telephoto like the 500mm, you either need to put a clamp directly on the monopod, or use their high-capacity head. As far as I know, it's the only such monopod head around that can support these heavy lenses.
-Liz
SYS
Gallery: 602 photos
Joined Jul 2004
Sep 13, 2008 08:30 |  #9
gymell wrote in post #6298561 (external link)
Yea, right now the 3229 suffices with my 70-200 and 100-400, but eventually I'll be getting the 500. Then I'll have to graduate to something like the reallyrightstuff. I bookmarked the product link for that purpose. Thanks for the link.
-Goethe
1,307 views & 0 likes for this thread, 4 members have posted to it.
Monopod for 40d
2691 guests, 142 members online
