Thread started 13 Sep 2008 (Saturday) 09:16
doubt my abilities,where do i g wrong?
macobee
Sep 13, 2008 09:16 |  #1
wheres the detail, where is th pop, what is wrong with me? pls help and suggest?
exif:
Camera: Canon EOS 350D Digital
Exposure: 0.006 sec (1/160)
Aperture: f/8
Focal Length: 50 mm
ISO Speed: 800
Exposure Bias: 0 EV
Flash: Flash fired
X-Resolution: 72 dpi
Y-Resolution: 72 dpi
Date and Time: 2008:09:13 21:21:14
Exposure Program: Manual
Date and Time (Original): 2008:09:13 21:21:14
Date and Time (Digitized): 2008:09:1​3 21:21:14
Shutter Speed: 8347/1140
Metering Mode: Pattern
Color Space: sRGB
Focal Plane X-Resolution: 3954.233 dpi
Focal Plane Y-Resolution: 3958.763 dpi
Exposure Mode: Manual
White Balance: Manual
Image Width: 3456 pixels
Image Height: 2298 pixels
http://www.flickr.com/​photos/marcoveringa/ (external link)
Benji
Sep 13, 2008 09:47 |  #2
Several things jump out to me. A silver reflector held just out of camera range and under the camera would have bounced some light back across the composition and added some pop. The leaves appear slightly wilted, slightly yellow and somewhat crammed into the bowl, one stalk is even broken. The lower tangled root is distracting as is the rather bright wooden table. The six red peppers are too many. Three is ideal. One seed in the lower lime is out of its socket. I like the general idea however, and the exposure appears to be OK.
Benji
Flo
Gimmie Some Lovin
Sep 13, 2008 09:59 as a reply to  @ Benji's post |  #3
Chef, too many things are on that plate.less is more with food, outside of the peppers, everything is monochromatic. White dinnerware is usually chosen instead of earthenware for the contrast abilities?
Solid color BG as well..but you are getting there:D
macobee
Sep 13, 2008 10:04 |  #4
hm thanks for your comments, it was just thrown together quickly, with the only purpose (after proper set ups failed) to see if i can get pop, talking food etc.....
anyhow......on my kneess back to the drawing board.....am not happy......but yes hopefully one day i get to pleasing phoographs.
thanks
Marco
Flo
Gimmie Some Lovin
Sep 13, 2008 10:11 as a reply to  @ macobee's post |  #5
http://www.foodportfol​io.com/frames/base_fra​me.html (external link)
He does some fabulous setups....
macobee
Sep 13, 2008 10:54 |  #6
thank you ill look into it right now!
macobee
Sep 13, 2008 10:57 |  #7
ooooooh Flo you spoiled my day now!!!
Flo
Gimmie Some Lovin
Sep 13, 2008 11:02 |  #8
macobee wrote in post #6299291 (external link)
Lol.good spoil or bad spoil?
macobee
Sep 13, 2008 11:07 |  #9
Bad one!!! defnitely a bad one............going o bed now cause tomorrow its mid autumn festival in Hong Kong and f888888 everybody wants to have dinner at the place i work......
ciao
iN5P1R3
Sep 13, 2008 12:20 |  #10
I agree with Flo. In this case, less is definitely more. The plate is way too cluttered and I'd chop off the roots as well :) On my monitor the image looks a bit warm too.
Photo Gear: Canon 60D, 85mm f1.8, Tamron 17-50mm f2.8 OS, 18-55mm kit lens, 580EX II
Custom built desktop :: 2.8GHz Intel Core i7 930 @ 4.0GHz||6GB DDR3||ATI Radeon 6870||8+ TB of storage||24" Samsung @ 1920x1080
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Sep 13, 2008 15:49 as a reply to  @ iN5P1R3's post |  #11
There is not anything wrong with you ... it is just that the lighting and food have conspired against you.;)
As the web site that Flo referenced says, food photography is a really big deal to make it look as good in print as it does when sitting on a plate in front of you. But, I did find it interesting that many of the images that the famous foodie shows on his site have large blown out areas ... maybe blowing out an image has been embraced as the latest style ... I do see it a lot in magazine advertisements. :confused:
As the others have said, how the food is displayed is all-important and I confess that I wouldn't know where to begin. However, I noticed several things that would help improve the image. I think that the main problem that the image does not look good to you is because the white balance is off. Fixing that would go a long way towards making the image more appealing. Other than that, the things that I see are:
  1. table is picking up too much glare from somewhere causing parts of it to have a washed out purplish hue.
  2. the cut edge of the lime has partially dried out.
  3. the pepper stems are turning brown -- that may be the best time to eat them, but not the best time to photograph them.
  4. the parsley is slightly wilted and old and has dried out ends on the stems where it is broken.
  5. overall, the lighting is too flat and harsh.
I like the particular plate that you are using and the wooden table top, but you will need to be careful about glare. I am posting a smaller version of your image to show how changing the white balance can help the overall impression.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
bbulldog
Sep 15, 2008 06:12 |  #12
I would also moisten the Coriander leaves too. might bring out a bit more colour in them, although they dont have that much on the undersides. Turn all the leaves upright..
If you want to leave the roots on them try not bending them and put the food on a small board??
Canon EOS 50D gripped
Canon EF-S 60mm f/2.8 Macro USM, EF 28-105mm f/4-5.6 USM, EF 75-300mm f/4-5.6 III USM
[COLOR=sandybrown][COL​OR=#000000][FONT=Comic Sans MS][COLOR=#ff0000][B]Canon EF-S 18-55mm f/3.5-5.6 IS Walimex 650-1300mm
Canon MR-14EX, Sigma EF-500 DG Super Flash, CELESTRON C6-SGT
macobee
Sep 16, 2008 05:48 |  #13
thank yu for your tips and comments, i think it has most to do with my lighting as i mostly have to shoot at night as im ll day out for work.
here some samples from what i can do with daylight available through my windows, much much better:
IMAGE: http://farm4.static.flickr.com/3212/2862474912_44c98a75e6_o.jpg
IMAGE: http://farm4.static.flickr.com/3005/2861644083_4d227f50d3_o.jpg
IMAGE: http://farm4.static.flickr.com/3205/2861643975_e926abe70e_o.jpg
Last one the focus is a bit off but nonetheless much better then the shot i started showing here at first!
Walczak ­ Photo
Sep 16, 2008 14:50 |  #14
macobee wrote in post #6315804 (external link)
Hey Macobee,
I can't really compare with your first shot as Flicr is saying the shot is unavailable, but over all I think these look pretty decent. The two biggest issues I'm seeing are basically white balance and DOF. First your colors look just a tich off to me...on my monitor at least. If you shot these in RAW, I'd go back and play with the color temp and/or tint just a bit more. I would also ask if your monitor is calibrated as well...that will certainly affect your color.
Secondly I think you're using too shallow DOF. I'd try closing down a couple of f/stops (aka use a smaller aperture). I have nothing against "selective focus" but I think it's just a little too selective here.
Otherwise I'd saying your framing/composition looks really good as does the sharpness (barring the fore mentioned DOF issue), contrast and saturation.
Just my $.02 worth,
Peace,
Jim
"It is horrifying that we have to fight our own government to save the environment. " - Ansel Adams
Walczak Photography - www.walczakphoto.izfre​e.com (external link)
tonybear007
Gallery: 95 photos
Sep 16, 2008 17:30 |  #15
Macobee,
First rate images. Well done. Looking at them made me hungry...
Tony
EOS 40D, Canon 24-70mm f/2.8L, 70-200 f/4L, TAMRON SP AF17-50mm f/2.8
Images from my EOS 40D (external link)
EOS 77D, 7D, Canon 16-35mm f/4L IS, Canon 24-70mm f/2.8L, Canon 100-400mm f/4.5-5.6L IS II
Birds Spotted in Florida (external link) Facebook
@BirdsSpotted (external link) Twitter
Canon 77D Facebook Page (external link)
@Canon77D (external link)
3,591 views & 0 likes for this thread, 9 members have posted to it.
2749 guests, 148 members online
