Thread started 13 Sep 2008 (Saturday) 14:58
Still getting red eye with the use of a flash bracket
chupacabra31
Sep 13, 2008 14:58 |  #1
Hi,
I have the Stroboframe Pro-Digital Folding Flip Flash Bracket which I am using with a 1dII and 400mm f5.6. I am doing fill flash with nature photography. I am following suggestions set out by Aurthur morris which is using ettl M mode along with 50mm and -1/3. I also have the camera set to P mode so that the shutter speed will not fall below 1/60. Anyway this bracket moves the flash up off the camera about 4 inches and I am still getting red eye in my subject, in this case I am testing it out on my dog indoors. Should I get another bracket that puts the camera even higher off the lens? Thanks!
Mike
ugly when I'm sober
Gallery: 51 photos
Sep 13, 2008 15:15 |  #2
Dogs eyes reflect light much more than human eyes so I would suggest that a dog is a poor subject for this kind of test. However, are you happy with your exposure otherwise?
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
chupacabra31
Sep 13, 2008 15:48 |  #3
michaelgreen78 wrote in post #6300314 (external link)
I have to say yes I am. I was just really annoyed that I am getting red eye still. What about birds are they going to be the same (for instance owls and herons)? That is my main subjects. I did a test with my flat mate and no red-eye at all. Exposure was no so great, but that is due more to my inexperience with portraits. Thanks for your help!
poloman
Sep 13, 2008 17:28 |  #4
Off camera will be better if possible.
You can also bounce the flash off of a nearby wall or the ceiling.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
chupacabra31
Sep 14, 2008 18:13 as a reply to  @ poloman's post |  #5
Do you think I will have problems with Owl eyes? Thanks.
Wilt
Sep 14, 2008 18:50 |  #6
chupacabra31 wrote in post #6300248 (external link)
Hi,
The angle formed by flash and lens to subject is too small with a long lens!
PacAce
Joined Feb 2003
Sep 14, 2008 19:32 |  #7
Hi,
You need to raise the flash much higher if you want to use a long lens like the 400 and shoot from a distance.
...Leo
tim
Light Bringer
Sep 14, 2008 19:44 |  #8
Wilt wrote in post #6306763 (external link)
PacAce wrote in post #6306922 (external link)
Exaccery. The flash will need to be a few meters above your lens, or a few meters to the side.
This is why actually understanding what you're doing is a good thing, rather than just going with what you read on forums. While you often get good advice there's no substitute for understanding how things work yourself.
chupacabra31
Sep 14, 2008 20:30 |  #9
tim wrote in post #6306976 (external link)
Exacery?? Is that a funny way to say Exactly in New Zealand? Incidentally I am just going off of what I have observed in the field from professional photographers (500-600mm lenses) equipment. In example you will see many setups if you go to Crane Creek, Ohio during migration. Almost all of them have flash brackets similar to the one I have. I have never noticed anyone with a 7 foot flash bracket lol.
tim
Light Bringer
Sep 14, 2008 20:48 |  #10
Sorry sometimes I type with an accent. People make the best light stands.
PacAce
Joined Feb 2003
Sep 15, 2008 07:08 |  #11
chupacabra31 wrote in post #6307198 (external link)
Everybody doing something doesn't necessarily mean that they're doing it right. It only take one person in a group doing it wrong and then the others copying his setup to make everybody else in the group doing it wrong. ;)
Obviously, you don't need a 7-foot bracket to shoot birds. However, you do need more than a 4-inch separation to reduce or eliminate "red-eyes". I use a Wimberley flash bracket with an extender to get my flash up high when shooting birds. I have a Stroboframe Pro-T which raises the flash higher than your bracket does and even that doesn't get the flash high enough. :)
...Leo
BobOh
Sep 15, 2008 11:15 |  #12
Just a thought on all this. Correct me if I'm wrong, but I think it may be somewhat of a crapshoot whether a photographer gets red eyes in the subject or not. I have a picture taken from probably 70 degrees from face on of a bride at a reception and she is exhibiting a slight case of red eye.
Regards,
Bob
Gear: 40D, 7D, EF 100-400L, EF 28-135, Speedlight 580EX and other stuff.
Flickr: http://www.flickr.com/​photos/bobbolew/ (external link)
Wilt
Sep 15, 2008 13:12 |  #13
BobOh wrote in post #6310439 (external link)
Not sure what you mean by 'from 70 degrees'...post an example of what you described.
The red eye phenomenon occurs because the light source illuminates the interior of the eye, and when the lens is at a shallow angle the lens sees the red interior of the eye. But when the light is at a greater angle, the lens no longer sees the illuminated interior of the eye. The subject needs to be looking at the lens and flash for the illumination to occur inside the eye and for the lens to see it.
BobOh
Sep 15, 2008 13:40 as a reply to  @ Wilt's post |  #14
Here is a heavy crop of the shot I'm referring to. By 70 degrees I mean I was 70 degrees away from looking at her and taking the photo head on. In this shot she has a slight bit of red eye in her left eye. So my thinking was if the flash (on the camera or on a bracket) was 70 degrees from head on, what good would it be to have one on a bracket if the shot is head on?
Regards,
Bob
PacAce
Joined Feb 2003
Sep 15, 2008 13:58 |  #15
It's not the angle from the flash to the face that's relevant. It's the angle between the lens and the flash. You usually get the most pronounced red-eye effect when the subject is looking directly towards the camera but as long as the pupil is visible no matter what the relative angle of the face is to the camera, it is still possible to get the red-eye effect as illustrated by your photo.
...Leo
1,888 views & 0 likes for this thread, 7 members have posted to it.
2880 guests, 134 members online
