One of the many I took while at the Reno Air Races this year.. more to come..
![]() | HTTP response: NOT FOUND | MIME changed to 'text/html' |
slcr1 Senior Member 421 posts Joined Dec 2005 Location: Seattle, WA More info | Sep 15, 2008 18:46 | #1 One of the many I took while at the Reno Air Races this year.. more to come..
- Josh
RCoulter Goldmember 1,703 posts Joined Aug 2006 Location: Reno,NV More info | Sep 15, 2008 19:24 | #2 The color looks a little "off" otherwise great shot Airliners.net
A2EVOMR Senior Member 662 posts Joined Sep 2007 Location: Ann Arbor, Michigan More info | That is an awesome shot, very sharp and a nice angle. I think it is a tad overexposed tho, the tops of the wings are blown out and you can't see any detail. 40D ~ EF 24-70mm f/2.8L USM ~ EF 50mm f/1.4 USM ~ EF 100-400mm f4.5-5.6L IS USM
casp3r Goldmember More info | Sep 16, 2008 06:31 | #4 Agree with above posts but still a great shot http://www.mcarberyphoto.co.uk
madplower4 Member 160 posts Joined Jan 2005 Location: Cincinnati More info | Sep 16, 2008 06:57 | #5 A2EVOMR wrote in post #6315896 That is an awesome shot, very sharp and a nice angle. I think it is a tad overexposed tho, the tops of the wings are blown out and you can't see any detail.
Gear: If she knew how much I've spent = DIVORCE!!
Sep 16, 2008 08:39 | #6 madplower4 wrote in post #6315998 As a rookie still learning, the shot seems perfect to me. What do you mean "blown out" and do you have any pics you can post for comparison. I realize it takes a trained eye, but the shot looks crisp as could be to my "weekend photographer" eyes. Can you explain, and what would you do to improve it? Once again, the more you learn about taking good pics, the more you need to learn about taking good pics!! When does the cycle end???? Thanks for any advice The white in the aircraft is too white. You've lost detail in the fuselage. It's great as far as sharpness, composition and timing though, imho. -- Don Fuller --
JamieHolladay Cream of the Crop 21,557 posts Likes: 3 Joined Nov 2005 Location: Gadsden, Alabama, USA More info | Sep 16, 2008 09:52 | #7 Nice shot. The Site
A2EVOMR Senior Member 662 posts Joined Sep 2007 Location: Ann Arbor, Michigan More info | Sep 16, 2008 18:01 | #8 madplower4 wrote in post #6315998 What do you mean "blown out". Can you explain, and what would you do to improve it? What I mean by blown out is the white surfaces on the aircraft that are into the sun are too bright or overexposed. See how they kinda hurt the eyes sort of speek, and any of the detail on the wing surfaces are washed out. It was hard for me to do an edit with a small image file, maybe someone else can do something better. Take away some Brightness and a tad down on the Exposure. What your looking for is a nice solid white color but also to have the entire picture properly exposed. 40D ~ EF 24-70mm f/2.8L USM ~ EF 50mm f/1.4 USM ~ EF 100-400mm f4.5-5.6L IS USM
Jeff Goldmember 1,462 posts Likes: 28 Joined Nov 2007 Location: 42° 34' N 87° 55' W Kenosha, WI More info | Sep 16, 2008 20:13 | #9 My first thought was WOW! I can see merit in the others' comments about being slightly overexposed. To see the difference, look at the seams between the panels just below the cockpit (in shadow). See the detail and definition between the panels? If it was that way across the entire top of the aircraft it'd be perfect. Jeff
Sep 16, 2008 22:32 | #10 Thanks guys! Actually, I need to re do the post processing and I think I'll have it corrected. - Josh
3Turner Rick Rolled Fanboy 26,511 posts Likes: 2 Joined May 2005 Location: San Antonio, TX USA More info | Sep 18, 2008 00:04 | #11 Nice shot and agree about the above on the PP....looking forward to the repost of it Robert | Gear |
| Latest registered member was a spammer, and banned as such! 2733 guests, 144 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
