Hi,
I intend to purchase a portait lens but i also want to capture freezed water droplet from fountain? what is the min f required?
cheers.
Ming
MFG Senior Member 537 posts Likes: 7 Joined Sep 2008 Location: South Australia More info | Sep 17, 2008 23:12 | #1 Hi, AIPP Accredited (Australia), WPJA
DDCSD GIVIN' GOOD KARMA 13,313 posts Likes: 3 Joined Jun 2007 Location: South Dakota More info | Sep 17, 2008 23:19 | #2 It all depends on your lighting more than your lens aperture. Derek
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Sep 17, 2008 23:19 | #3 Aperture doesn't directly matter - it's shutter speed that affects motion blur. A faster aperture will allow you to get a faster shutter speed and freeze the water... Gear Listhttp://www.codastudios.com.au
Sep 17, 2008 23:26 | #4 Just got a 450D camera with the standard kit lens yesterday. I tried to alter the speed to the fastest but it is stopped or "flashing" limited by the "f" of the lens. AIPP Accredited (Australia), WPJA
BigBlueDodge Goldmember 3,726 posts Joined May 2005 Location: Lonestar State More info | Sep 17, 2008 23:28 | #5 What mode do you have the dial on? What you are most interested in is shutter speed. Shutter speed stops movement. Make sure the dial is on "Tv", and set the shutter speed to 1/500 (which should be sufficient to stop motion). Your camera will then adjust the aperature to expose properly. David (aka BigBlueDodge)
Sep 17, 2008 23:30 | #6 Wouldnt that be limited by the lens f3.5-5.6 then? AIPP Accredited (Australia), WPJA
rcfury Senior Member 916 posts Likes: 1 Joined Dec 2007 Location: Manassas, VA More info | Sep 17, 2008 23:35 | #7 If you need to increase your shutter speed for stopping motion you need light. So you can can either stop down your lens (smaller f-stop) to increase your aperture or increase the ISO. If you choose a shutterspeed that cant be used because of the situation, IE not enough light, the camera will start flashing the shutterspeed to remind you that, the shutterspeed / aperture combo will not work. ~Nathan
Sep 17, 2008 23:36 | #8 thanks people. AIPP Accredited (Australia), WPJA
Sep 17, 2008 23:43 | #9 Depending on lighting conditions you may need a shutter speed of 1/1000s or faster to freeze water droplets. The faster the shutter speed the wider the aperture needs to be (assuming all other variables remain constant). This is where the maximum lens aperture makes a difference. EOS 77D, 7D, Canon 16-35mm f/4L IS, Canon 24-70mm f/2.8L, Canon 100-400mm f/4.5-5.6L IS II
Ingsy Senior Member 726 posts Joined Sep 2007 More info | Sep 18, 2008 05:22 | #10 I took some photos of milk splashing into a cup of coffee. I used the 50mm 1.8 wide open, ISO 800, some extra lamps and could use a shutter of 1/4000 if I wanted too. Zenfolio
EOS_JD Goldmember 2,925 posts Likes: 2 Joined Dec 2005 Location: Lanarkshire, Scotland More info | Sep 18, 2008 06:06 | #11 MFG wrote in post #6330817 Wouldnt that be limited by the lens f3.5-5.6 then? EF-S 18 - 55mm f/3.5-5.6 IS forget to mention that i told the picture indoor at night with ceiling lights on. cheers Might be an idea to learn about exposure. All My Gear
Abundance3 Hatchling 6 posts Joined Sep 2008 More info | Sep 18, 2008 06:24 | #12 Think of freezing water as fast action shots.
Harold Edgerton
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Sep 18, 2008 16:33 | #14 Even with dark lenses, you could always bump the ISO to get the shutter speed up. A flash would also work, but might not give the look you're after. La Vida Leica!
DAMphyne "the more I post, the less accurate..." More info | Sep 18, 2008 16:58 | #15 Really, the shutter speed has less to do with freezing action when you use a flash. David
| Latest registered member is EBiffany 957 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
