Thread started 18 Sep 2008 (Thursday) 19:36
Getting pen off an LCD monitor
tim
Light Bringer
Sep 18, 2008 19:36 |  #1
A friend of mine has a 24" HP LCD, yesterday his 2 year old drew on it with a standard pen. Does anyone know how to get it off without damaging the screen?
20droger
Sep 18, 2008 20:15 |  #2
First, a cloth damp (not wet) with a mild detergent and water.
Then try isopropyl (rubbing) alcohol. If that doesn't do it, try ethyl (grain) alcohol, which can be obtained from drug stores and most hardware stores.
Careful! I suggest you avoid methyl (wood) alcohol. Most LCD screens can be damaged by methyl alcohol.
Test any cleaning substance on a corner of the screen, using a Q-tip. Moisten just a tiny spot, let it dry completely, wipe the area with a damp cloth, and see if any residue remains or damage exists. If not, then that particular cleaning substance is probably safe to use on the screen as a whole.
Good luck.
FlyingPhotog
Cream of the "Prop"
Sep 18, 2008 20:16 |  #3
Simple Green...
Jay
tim
Light Bringer
Sep 18, 2008 20:20 |  #4
Thanks guys, more suggestions welcome :)
SlowBlink
"I like dog butts"
Sep 18, 2008 20:35 |  #5
Lighter fluid is also very good at removing oil based inks without damaging plastics. Wash with a mild soap after of course.
Rob
Anatidaephobia - The Fear That You are Being Watched by a Duck.
Mark
Dammit I need sleep
Sep 18, 2008 21:22 |  #6
Pine-O-Clean :)
Mark
greg20d
Typo King
Sep 19, 2008 08:50 |  #7
SlowBlink wrote in post #6337090 (external link)
or throw a match at it
40D,10d,G10,70-200Lf4is,17-55is
tsw910
Sep 19, 2008 10:30 |  #8
i am not sure Tim .. but never tried on a screen before .. but nail polish remover usually work removing anything off of anything ... but i would try on a small spot first to see if it will cause any damages
Scuba Tom
http://tomwangphotogra​phy.com (external link)NYC Wedding Photographer (external link)http://www.tomwangphot​ography.com/ (external link)
Pete
Sep 19, 2008 10:31 |  #9
tim wrote in post #6336752 (external link)
Tippex?
:D
Pete
UK SE Catch of the Day
Kristy
Gallery: 31 photos
Location: A dream world where nothing is what it seems.
Sep 19, 2008 10:32 |  #10
Hairspray will take ink off of clothing.. but I'm not sure what it would do to the LCD...?
I'll be a smart a** now and say the best remedy is to remove all pens from the reach of a 2 year old,
and closely supervise.. If he does damage, then you hang him up by his toes for a couple of hours.. and
he won't do it again. (totally kidding of course... ;) )
Life is not measured by the number of breaths we take,but by the moments that take our breath away.
~George Carlin
Kristy :D 5D MkIII, 24-70 / f2.8 L, 2 AB800's, and some modifiers.
My Website Page (external link)
Michael_Lambert
-ColdMember-
Sep 19, 2008 10:41 |  #11
anther vote on Simple Green.
My neice thought it was fun to outline her dads picture on his laptop with perma marker... however he caught it right away and cleaned it with Simple green right away and it worked fine.
My Canon Gear
Michael Lambert Photography (external link)
jeffrf
Sep 19, 2008 12:41 |  #12
WD-40 also sorks for cleaning that stuff up, careful on plastic surfaces though.
http://www.flickr.com/​photos/11037896@N05/ (external link)
20droger
Sep 19, 2008 16:56 as a reply to  @ jeffrf's post |  #13
That's the trouble with naphtha (lighter fluid) and acetone (nail polish remover. Whether or not they will damage the surface depends upon the kind of plastic involved.
Acetone, for instance, is used to cold weld plastic eyeglass frames. That means it will dissolve that kind of plastic.
SlowBlink
"I like dog butts"
Sep 21, 2008 18:46 |  #14
Check with a local art supply store. They used to sell a blue cleaning fluid in Canada and it would flush everything out of my airbrush no matter how old or stuck. They had to stop selling it because it did the same thing to personal cheques.
Rob
SteveBrown
Sep 22, 2008 00:43 |  #15
Before you do anything, do a test spot in the corner or something.
Nikon D300 and other non canon stuff, I just like this place. MOOOHAHAHAHA :p
2,674 views & 0 likes for this thread, 13 members have posted to it.
2210 guests, 103 members online
