Ladies and gents, newbies, amateurs and pros help me out please. In trying to explain the f-number/shutter speed relationship I thought of using a simple illustration below.
I want your brutally honest opinion as to whether I simplified the subject or made it more complicated.
Understanding the Shutter Speed / f-number combination
Let’s assume that you are given a task to fill a tank that has a capacity of 48 gallons. You are given a choice of 5 buckets. The buckets have capacities of 1 gallon, 2 gallons, 3 gallons, 4 gallons and 6 gallons. The source of water is a lake a few yards away.
Here are your options:
1 gallon X 48 trips = 48 gallons
2 gallons X 24 trips = 48 gallons
3 gallons X 16 trips = 48 gallons
4 gallons X 12 trips = 48 gallons
6 gallons X 8 trips = 48 gallons
As the illustration shows varying the size of the bucket and the number of trips can accomplish the same task. However there is a pattern that should be noted.
As the size of the bucket increases the number of trips decreases. In mathematical terms this is called an INVERSE relation. As one factor increases the other factor decreases to maintain a constant result.
This is also true of exposure settings. As shutter speed increases the f-number decreases to achieve the same exposure, assuming ISO remains constant. You could also say that as shutter speed decreases the f-number increases to maintain the same exposure.
(Decreasing the f-number means the lens opening or aperture is getting larger. At f2.8 the aperture is large while at f16 it is small.)
What’s the practical value of this information?
Let’s say your camera recommends an exposure setting of 1/250 f8. This exposure is the same as 1/500 f5.6 and 1/1000 f4.0.
A likely question is what difference does it make if all 3 settings give the same exposure?
This is where the matter of creativity comes into play. At f16 the aperture is small and the depth of field is deep. This is ideal for photographing landscapes or large crowds.
At f4 the aperture is large and the depth of field is shallow. This is more suited to macro photography where you want the background to be out of focus.
Ps. f1.4, f2.8, f4.0 are large apertures and produce shallow depth of field
f11, f16, f22 are small apertures and produce an extended depth of field
EOS 3 (35mm film), EOS 40D, Canon 24-70mm f/2.8L, 70-200 f/4L, TAMRON SP AF17-50mm f/2.8
Aperture, Shutter Speed and Creative Zone Modes Explained![]()
