Thread started 19 Sep 2008 (Friday) 08:21
Off Camera 430EX question
LoL ­ Ish
Sep 19, 2008 08:21 |  #1
Can I use a single 430EX flash off camera, without having to use, say, a 580 EX II as a master?
Sorry for the nubish question. But to this type of lighting, I am a nub. ;)
-Kyle
- Kyle
The Gearhttp://www.photosig.co​m/go/photos/browse?id=​33229 (external link)
Deadeye008
Sep 19, 2008 08:44 |  #2
You can use it off camera but you will need either a cord or some kind of a wireless trigger to set it off. I use Cybersyncs with my 430EX and they work great.
Hamblin Photography (external link)
Matthew ­ Patrick
Sep 19, 2008 08:56 as a reply to  @ Deadeye008's post |  #3
Here are the three major options for wireless off camera flash. If you use an RF system you will need an adapter that hooks onto the shoe mount of you 430 EX as these do not have a sync port. You can pick one up at www.flashzebra.com (external link) for about $12.
The first is to trigger the remote flash using Canon's proprietary infra red (IR) system which allows for use of E-TTL but requires another Canon 430 EX or 580 EX flash or an ST-E2 transmitter. The IR system has problems in bright sunlight and requires line of sight, (it's like an IR T.V. remote you have to point it at the T.V.) it has a limited range of about 30 feet.
The second option is to use a set of radio frequency (RF) flash transmitters/receivers or transceivers like Pocket Wizards. They do not allow for use of E-TTL so you must use manual flash settings. You will need one for the camera (to transmit) and one for each off camera flash (to receive). They cost about $190 ea. and you need at least two. If you don't want to invest that much money you can buy cheaper RF flash triggers. RF triggers do not require line of sight so you can mount a flash behind a wall or something and it will fire. They work like household cordless phones rather than the IR T.V. remote.
The third is an older device called an optical slave. Unlike the Canon IR system these can be used in conjunction with RF triggers like Pocket Wizards. Optical slaves will trigger an off camera flash when they sense the light emitted from another flash or strobe (The Canon IR system emits a pre-flash to judge distance this will prematurely fire an optical slave). These are cheap you can get one at www.flashzebra.com (external link) for about $12 or $14. They are nice if you only have two Pocket Wizards and you want to trigger more than one off camera flash.
You should check out www.strobist.blogspot.​com (external link). Read lighting 101, this will help fill you in on all the good stuff that I left out. Also check out www.flickr.com/groups/​strobist/discuss/ (external link) this is a forum for off camera flash.
dpds68
Sep 19, 2008 09:26 |  #4
Matthew Patrick wrote in post #6339894 (external link)
430Ex can only be used as a Slave not a Master
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 19, 2008 10:31 |  #5
Do you plan to use the flash in ETTL or manual mode?
If you use the first option, you can use ETTL just as if the flash is on the camera. (also available using an off camera shoe cord like OC-E3)
If you use any other option, you MUST use the flash in manual mode.
(in addition to wireless, you could also use a PC sync cord with adapters to fire the flash in manual mode while off camera)
Titus213
Sep 19, 2008 11:00 |  #6
The 430EX will not generally play well with optical triggers.
If you want to keep ETTL your options remain spendy. Unless you want to build your own long off-shoe cord (standard cord is about 2 feet). Then you only buy the original cord for $80 and the wire/fittings to extend. The instructions are on this site somewhere.
If you will go to manual on the flash you can do it with a PC cord for about $30 depending on how far you want to go. www.flashzebra.com (external link) will have what you need. The 350 doesn't have a PC connection so you will have to add a hot-shoe to PC unit.
Dave
Perspiring photographer.
LoL ­ Ish
Sep 20, 2008 12:06 |  #7
Titus213 wrote in post #6340629 (external link)
Do you mean the 350D?
Right now, I'm looking at lightstands and softbox options. I'm reletivly cheap, so I'm not going out for the most expensive brand. These are what I've come up with.
Impact Compact 6Ft. Lightstand
http://www.bhphotovide​o.com …5_Light_Stand_B​lack_.html (external link)
PhotoFlex 12x16 soft box
http://www.bhphotovide​o.com …me_Q39_Softbox_​White.html (external link)
PhotoFlex shoe mount connector (this is needed to use the flash with the softbox, right?)
http://www.bhphotovide​o.com …Shoe_Mount_Conn​ector.html (external link)
- Kyle
Titus213
Sep 20, 2008 12:50 |  #8
LoL Ish wrote in post #6346542 (external link)
Sorry, yes I mean the 350D doesn not have a PC plug.
I'm not familiar with the soft box but I have several light stands. 2 10' and a 13'. I would find the 6' stand too short I think. I often grab the 13' stand because of its wider stance.
The rest sound like a lot of small, expensive pieces. Why not umbrellas?
Dave
LoL ­ Ish
Sep 20, 2008 14:56 as a reply to  @ Titus213's post |  #9
Because I would also like to use the lightstands outdoors, and if it's windy, I don't want the umbrella to cause the stand to fall down. Or does it really even matter? I could always go with just a single umbrella.
Well instead of the softbox, I suppose I could get these two things.
Umbrella Bracket (external link)
Translucent Umbrella (external link)
It is cheaper, but how sturdy or portable would this be compared to the soft box?
- Kyle
Titus213
Sep 20, 2008 17:35 |  #10
I do not own but have used this kit on several occasions: http://www.bhphotovide​o.com …Flash_Umbrella_​Mount.html (external link)
It seems to be a reasonable starter kit.
Dave
LoL ­ Ish
Sep 20, 2008 17:50 as a reply to  @ Titus213's post |  #11
I looked at that kit a while back too. Just, for right now, I only need one.
- Kyle
1,392 views & 0 likes for this thread, 6 members have posted to it.
2784 guests, 142 members online
