Just got a Canon TC 2x for use with 100-400 L IS USM, mainly for Moon shots. AF is gone with this combination. I can live with manual focus but was wondering is there any way around this?
Pixels Senior Member 454 posts Likes: 5 Joined Jul 2003 Location: Ireland More info | Sep 19, 2008 09:53 | #1 Just got a Canon TC 2x for use with 100-400 L IS USM, mainly for Moon shots. AF is gone with this combination. I can live with manual focus but was wondering is there any way around this? Canon 24-105 L IS USM,
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | Sep 19, 2008 10:14 | #2 Here's a shot I took last night with my 100-400 and Kenko 1.4X teleconverter. With that combination you can tape over some pins to hide the teleconverter from the camera so that it will continue to (try) to autofocus, but with a 2X teleconverter you may as well forget it. At f/5.6 plus a 2X teleconverter you will effectively be at f/11 and the AF will be hopeless, even if you could get it to try to function.
To fill the frame across the short dimension would pretty much need a 1200mm lens plus the 1.4X. Here's what the full frame looked like before cropping....
Thanks for that Tim. I had figured AF was not an option, so will adapt to MF for these shots. Am looking forward to trying lunar shot when it next appears! Canon 24-105 L IS USM,
edrader "I am not the final word" More info | Sep 19, 2008 11:36 | #4 Pixels wrote in post #6340776 Thanks for that Tim. I had figured AF was not an option, so will adapt to MF for these shots. Am looking forward to trying lunar shot when it next appears! is AF important for a shot like this? http://instagram.com/edraderphotography/
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | Sep 19, 2008 11:48 | #5 In my limited experience, no.
TeamSpeed 01010100 01010011 More info | Sep 19, 2008 11:53 | #6 I taped the pins on my Kenko 2x and snapped off some shots with AF, there are some samples in this archive. Past Equipment | My Personal Gallery
Sep 19, 2008 12:52 | #7 No. My query was relating to use of TC generally. Canon 24-105 L IS USM,
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | Sep 19, 2008 13:08 | #8 The pro bodies (1 series) are designed to work with lenses having apertures of f/8 or faster, but I think f/8 is only OK on some AF points (not certain about that). The non-pro bodies are only designed to work with lenses having apertures of f/5.6 or faster.
mrklaw Senior Member 678 posts Joined Jan 2006 More info | curious - whats the difference between a 5.6 lens in low light, and an f8 lens in bright light? Is there a reason there is a particular limit to the max. aperture for focusing and not simply an available light limit? _______________
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | Sep 19, 2008 13:43 | #10 It's not about the brightness of the light. It's about the angles from which the light hits the focus points and the phase differences that result when things are not focused correctly. The larger the aperture the broader the spread of angles from which the light is focused onto the AF points. While good light is important, and good contrast, you still need enough phase differential for the AF to calculate where things need to be moved to. The smaller you make the aperture the smaller the phase difference becomes and the less data the AF has to work with.
usingthejohn Senior Member 369 posts Likes: 1 Joined Feb 2008 Location: buena park, ca More info | Nov 15, 2008 10:49 | #11 been thinking of this combo, with this in mind: Gripped 50D
5Dmaniac Goldmember 1,303 posts Likes: 1 Joined Oct 2008 Location: Scottsdale, AZ More info | Nov 15, 2008 11:00 | #12 The 100-400 with the 2x TC will give you pretty lousy results - irrespective of the AF (which won;t work of course). I use my 100-400 with a 1.4 and the result is OK, but with the 2x TC the quality is just too bad.
TeamSpeed 01010100 01010011 More info | Nov 15, 2008 11:13 | #13 5Dmaniac wrote in post #6692069 The 100-400 with the 2x TC will give you pretty lousy results - irrespective of the AF (which won;t work of course). I use my 100-400 with a 1.4 and the result is OK, but with the 2x TC the quality is just too bad. Completely depends on your body, and the quality of both the 100-400, the TC, and how well adjusted this combo is to the body. The blanket statement here is not always the case. And again, regarding the working AF, depends on the TC and body. Past Equipment | My Personal Gallery
edrader "I am not the final word" More info | Nov 15, 2008 11:37 | #14 5Dmaniac wrote in post #6692069 The 100-400 with the 2x TC will give you pretty lousy results - irrespective of the AF (which won;t work of course). I use my 100-400 with a 1.4 and the result is OK, but with the 2x TC the quality is just too bad. i've never tried the 2x TC on my 100-400L but i have tried the 1.4 combo and it's not something i will use. http://instagram.com/edraderphotography/
Stickman Goldmember 1,966 posts Likes: 10 Joined Nov 2006 More info | Nov 15, 2008 11:38 | #15
Stick
| Latest registered member is semonsters 1550 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
