Thread started 08 Feb 2005 (Tuesday) 07:51
Polarizing filter question.
ajbalazic
Joined Jan 2005
Feb 08, 2005 07:51 |  #1
A couple of questions regarding polarizing filters:
#1. Is it common practice to increase exposure when using a polarizing filter? I'm looking to achieve a deep blue sky color which leads me to the second question...
#2. What is the best position of the sun and time of day to maximize the effect of the filter for the sky.
I'm curious to hear what you have to say. You can read books but it seems to me that by trying it yourself and asking experienced people is the best way to learn.
Thanks,
Alan
Alan
sdommin
Joined Dec 2002
Feb 08, 2005 08:25 |  #2
You definately have to increase your exposure by 1 or 2 stops, sometimes more. The amount of polarized light varies, so you have to experiment. A polarizer cuts out a lot of light, so you need to compensate even if you want your skies dark blue.
As a "rule of thumb" (pun intended), extend your pointing finger and your thumb. Point your finger at the sun. Rotate your wrist and your thumb will point at the areas of maximum "blueness" in the sky. Obviously, you need to have some blue sky showing; cloudy days aren't good for polarizers (except for things like eliminating reflections from glass, etc.).
Scott
http://www.pbase.com/s​dommin/favorites (external link)
mdr
Joined Jan 2005
Feb 08, 2005 08:58 as a reply to  @ sdommin's post |  #3
Your TTL metering should compensate for the loss of light.
The short version of the rule of thumb is: angle your lens at 90 degrees from the sun.
Marc
Glasgow, Scotland
www.marcderidder.com (external link)
www.deridder.me (external link)
scottbergerphoto
Joined Jun 2003
Feb 08, 2005 09:52 as a reply to  @ mdr's post |  #4
These were shot Saturday with a 20D, 16-35 f/2.8 and a B&W 77mm Circular Polarizer. I used partial metering off the sky. You try to position your lens at 90 degrees to the sun for maximum effect and rotate the outer ring of the CPL to get the effect you want.
IMAGE: http://www.pbase.com/scottbergerphoto/image/39458444.jpg
IMAGE: http://www.pbase.com/scottbergerphoto/image/39458449.jpg
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
ajbalazic
Joined Jan 2005
Feb 08, 2005 14:08 as a reply to  @ scottbergerphoto's post |  #5
Thanks.
Alan
FlyingPete
I am immune
Joined Oct 2003
Feb 08, 2005 17:04 as a reply to  @ ajbalazic's post |  #6
Has anyone found that due to the darkened sky, the camera (20D in my case) tends to overexpose by about half a stop (depends on the amount of sky in the image)?
I usually have to compensate or meter entirely of the foreground to get nice skies like Scotts first shot there.
Peter Lowden.
EOS R6 and assorted glass
clorich
Joined May 2003
Feb 08, 2005 20:09 as a reply to  @ FlyingPete's post |  #7
This was taken on my G2 with a linear polarizer. As long as you're patient, you just spin the polarizer until you get the look you want.
robertwgross
Joined Nov 2002
Feb 08, 2005 20:48 as a reply to  @ FlyingPete's post |  #8
In general, no. If anything, my camera underexposes blue sky with a polarizer.
When it gets a little weird is if you are using a fairly wide lens. The degree of polarization changes radically when you go from one side to another on the wide lens, whereas, it would not be so different with a longer lens. Anyway, the result is that you can get a very light sky on one side and a very dark blue sky on the other side. So some viewers claim that it looks fake. You can avoid some of that complaint by not cranking the polarizer all the way to its maximum. I've tried about 50% with good results.
---Bob Gross---
johnathanesper
Feb 09, 2005 12:00 |  #9
what reasonably priced polarizing filter would you recommend for the Canon 20d? (I know pretty much nothing about quality issues on this topic)
scottbergerphoto
Joined Jun 2003
Feb 09, 2005 12:49 as a reply to  @ johnathanesper's post |  #10
B&W or another high quality multicoated Circular Polarizer.
It doesn't pay to put a cheap filter in front of a good lens.
Scott
Best Regards,
Scott
Chris ­ P ­ Bacon
Joined Jul 2004
Feb 10, 2005 09:41 |  #11
are the canon polarizers any good? nobody ever seems to mention them
gramps
Joined Oct 2004
Feb 10, 2005 09:44 as a reply to  @ johnathanesper's post |  #12
Which lens? Scott is right ...............DON'T use a cheap filter.
Some pics here - http://pbase.com/sjh (external link)
20 D; 85 1.8; 24-70 L; 70-200 f4L (sold); 100-400 L; 420 Light bulb
1550 Pelican "soft case" & too much junk!!!
2,598 views & 0 likes for this thread, 10 members have posted to it.
1975 guests, 103 members online
