Hi, Can someone explain a way to fix her scar on her tummy, so its not so pronounced? I have CS3.
Thanks in advance,
Teeny
poloman Cream of the Crop 5,442 posts Likes: 7 Joined Dec 2006 Location: Southern Illinois More info | Sep 21, 2008 22:21 | #2 Sure...Clone it out. Select the clone tool and start on your right side make your brush as large as possible and still get consistent light. Then start cloning leftward in fairly small increments. Work at it till you are happy and then select the liquify filter. A little work with the pucker tool and the warp tool will help her. "All those who believe in psychokinesis, raise my right hand!" Steven Wright
Thanks Poloman, but mine does not look as good as yours.
shannyD "...in too much trouble" 5,219 posts Likes: 1 Joined Jul 2007 Location: scrotumento CA, miss NC, and lived in th north east for a while, and even in the mid west for a bit. More info | Sep 22, 2008 14:42 | #4
Hi, thanks. Do you mind sharing how you did that? I tried the other way and it looked to white.
shannyD "...in too much trouble" 5,219 posts Likes: 1 Joined Jul 2007 Location: scrotumento CA, miss NC, and lived in th north east for a while, and even in the mid west for a bit. More info | Sep 22, 2008 14:51 | #6 i went to the filters menu after creating a new layer, and used the pucker tool.. to suck her in a little bit.. then cloned out the crease in her tummy.
Thanks Shanny, I will try that too. By the way, can you post a full res. photo? How?
shannyD "...in too much trouble" 5,219 posts Likes: 1 Joined Jul 2007 Location: scrotumento CA, miss NC, and lived in th north east for a while, and even in the mid west for a bit. More info | Sep 22, 2008 16:34 | #8 you can email full resolution pics.
| Latest registered member is Mihai Bucur 1183 guests, 170 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
