New 20D user. Old 380ex flash. Even with ot door shots for fill effect faces are way overexposed. Will 580ex help or is it just that I don't know what I'm doing. I was using full auto mode, by the way. Thanks
m.uzer Hatchling 2 posts Joined Feb 2005 More info | Feb 08, 2005 13:19 | #1 New 20D user. Old 380ex flash. Even with ot door shots for fill effect faces are way overexposed. Will 580ex help or is it just that I don't know what I'm doing. I was using full auto mode, by the way. Thanks
elbirth Goldmember 1,886 posts Joined Jul 2003 Location: North Carolina More info | Feb 08, 2005 14:12 | #2 Welcome to the forums! 5D Mark II, Leica M8
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Feb 08, 2005 14:49 | #3 Flash shots are difficult, there's no way around it. The 20D should be using ETTL-II to provide the correct flash strength, but I wonder if an old flash is compatible. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
jfred Member 125 posts Joined Jan 2005 Location: Bedfordshire, England More info | Feb 08, 2005 16:01 | #4 AE lock at the centre metering point has (so far) worked well for me. I'm only two weeks into 20d ownership, so still working some of this stuff out. Canon EOS 20D, 580ex, MR-14, 10-22, 50mm f1.8, 100mm f2.8 macro, 70-200mm f4L
MrChad Goldmember 2,815 posts Joined Aug 2004 Location: Chicagoland More info | jfred wrote: AE lock at the centre metering point has (so far) worked well for me. I'm only two weeks into 20d ownership, so still working some of this stuff out. What point is the camera metering on for you? Have you tried choosing an exposure point, or Flash AE lock? I use AE lock always with the 420EX flash and the center AF point. I've had nothing but good shots. I alwasy use the M, Av, And Tv modes as well. I kaNt sPeL...
Marvinspu36 Member 229 posts Likes: 1 Joined Feb 2005 Location: California More info | Feb 08, 2005 17:22 | #6 I'm just a beginner, so take what I say with a grain of salt. Canon 6D & 20D with battery grips, EF-S 18-55mm, EF 50mm f/1.8 II, EF 70-200mm f/4L, EF 24-70mm f/2.8L, EF 70-200mm f/2.8L IS, 600EX-RT, 580EX, 420EX's, Epson P-2000, some umbrellas and other stuff...
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Everybody take a deep breath and repeat after me, "ETTLII has nothing to do with the active autofocus points." There is alot of useful information on this issue in the EOS Flash Sticky. One World, One Voice Against Terror,
JasonW Senior Member 293 posts Joined Feb 2005 Location: Adelaide, South Australia More info | The 380EX is an EX series flash so it should work with ETTL-II. I have the same flash on a 20D and tend to get under exposed results (2/3 stop). I wonder if it is a metering issue???
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | scottbergerphoto wrote: Everybody take a deep breath and repeat after me, "ETTLII has nothing to do with the active autofocus points." There is alot of useful information on this issue in the EOS Flash Sticky. Scott Scott, you can send them to school, you can give them books, you can explain it in the Sticky, but they still don't get it, do they?
| Latest registered member is AlainPre 1767 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
